05-05-2013, 08:36 PM
New to 5th Wheel Question
When I pull my 5th wheel home from storage the night before we leave to pack and get my fridge cold, do I need to unhook from the truck or can I leave it hooked up over night? My real question is will it do any damage to the truck to sit for 24 hours with the 5th Wheel hooked on and all the weight on the truck?
Thanks!
'12 Dodge 3500
'13 Crusader 295rst
05-05-2013, 08:41 PM
Thanks!
If you're worried about it, run the landing jacks down to take the load off.
But, it shouldn't be any difference than towing for 24 hrs.
05-05-2013, 08:49 PM
If it were me, I would set the landing gear down and remove some/most of the weight from the truck. No reason to leave that load on the truck overnight if you don't have to.
Kevin & Janine
2019 F350 Lariat DRW
2020 Jayco Pinnacle 36KPTS
05-05-2013, 08:53 PM
That is what I was thinking. Thanks for the responses!
'12 Dodge 3500
'13 Crusader 295rst
05-05-2013, 09:02 PM
William
You have no worries about keeping the weight on it over night. You are talking about your Ram 3500?
2012 Crusader 320RLT
2011 F250 Lariat 6.7L
2016 (19 Nights Camped/1348 Miles)
2015 (38 Nights Camped/3560 Miles)
2014 (28 Nights Camped/1980 Miles)
2013 (30 Nights Camped/1411 Miles)
05-05-2013, 09:17 PM
I know a few racers that never unhook their 40'+ race trailers all summer long. Over night should be no big deal.
2015 Sierra 357TRIP
2012 Ram 2500 CCSB 6.7CTD
05-05-2013, 09:31 PM
The other thing you have to consider is the fridge level, if you remain hooked up to the truck?
Of all the things I've lost in my life the thing I miss the most is my mind!
05-05-2013, 10:40 PM
Yes
'12 Dodge 3500
'13 Crusader 295rst
05-05-2013, 11:02 PM
I usually leave mine connected to the truck but do put the landing gear down not just to get a little bit of the weight off of the truck, but more so to add a little bit more stability to the camper. Without it down it really moves around a lot as we are loading and unloading. I just raise it enough to shift the weight to the landing gear, not enough to raise it off the hitch.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
05-06-2013, 07:27 AM
Always Learning
We usually leave it hitched up- sometimes for a day or two or three depending on when we go fetch the camper. We do level it up if we're going to be in and out a lot. Leveling is 4-lynx levelers high. Just going in/out, the movement doesn't bother us.
I've also done overnight stops on the way home and left it hitched up. That time I did run the landing gear and stabilizers down for comfort while we all we inside.
No worries!
05-06-2013, 07:28 AM
Always Learning
It's not a whole lot difference leaving a load in the truck bed. I took 1,500 pounds of yard waste to the dump 5 days after we loaded it into the truck. My pin weight is about 2,300 so it wasn't as much- but same idea.
05-06-2013, 07:51 AM
Camper Less Camping
X2
2013 Sabre 32RCTS-6 (sold)
05-06-2013, 07:56 AM
This is why I run the landing gear down when I am hooked up for a short overnight stay and an early (before quiet hours) launch. Last thing I want is the fridge to stop working due to coolant pooling in the coils.
I also disconnect the umbilical cord from the truck.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
05-11-2013, 10:29 PM
If the campsite is level and we want to get an early start we don't unhook, put down any stabilizers or connect water; just plug in the power.
05-11-2013, 10:32 PM
My camper is not level when we are connected to the truck on a level surface; it is slightly nose down.
05-11-2013, 11:12 PM
Always Learning
I think I'm the same, though I haven't measured to confirm. But- when we overnighted for an easy getaway the next day, we did drop the landing gear and between the squat in the truck and play in the hitch, we were able to level front to back and stay hitched. Saved us a little time in the morning.
05-11-2013, 11:16 PM
Denver, CO
I thought that absolutely level was not needed in the current generation refers.
2017 Fuse 23T
05-12-2013, 12:02 AM
Always Learning
I know I don't worry about it- but I've been wrong before. :-)
05-12-2013, 09:04 AM
To be level without unhitching I have placed boards, underneath truck tires to correct for nose down, underneath trailer tires for nose high, and under one side or the other for side to side! After leveling stabs down to minimize rocking. I kept telling my brother he needed to be more level, didn't believe me until fridge had to be replaced, older trailer, quite expensive!
05-12-2013, 09:34 AM
Level seems to still be very important as we have a friend that their frig stopped working sitting "on" & not level.........
Just remember if you put the landing gear down to put it up before leaving...... If level should be no big deal leaving hooked up.... Shouldn't hurt a 3500 to be left hooked up .....
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
