Old 08-17-2013, 06:42 AM   #1
Wardell240's Avatar
New to Fifth Wheel camper
We just bought a 34 foot Fifth wheel. We have been out 2 times and we are having a lot of movement when people walk around. I've got 2 of the x looking wheel chocks ordered. People say that will help what do you guys think about the tripod for the front dose that help??
Wardell240 is offline   Reply With Quote
Old 08-17-2013, 06:58 AM   #2
Camper Less Camping
Cajun Po-Boy's Avatar
Good start with getting a pair of xchocks for tires...IMO, skip the tripod setup.
I'd look into the stabilizer bars for the front landing gear & rear jacks...when in combination with the xchocks, you will be very pleased on how solid the camper will feel
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 08-17-2013, 07:11 AM   #3
Wardell240's Avatar
Thank you for the info ill look it up
Old 08-17-2013, 08:11 AM   #4
My advice too: skip the tripod and go with stabilizers. Will help a lot.
Flying dutchman is offline   Reply With Quote
Old 08-17-2013, 08:14 AM   #5
Check out JT Strongarms
JTRV.COM
Old 08-17-2013, 08:17 AM   #6
Great Horned Owl's Avatar
The easiest and least expensive solution is to quit worrying and just learn to ignore the movement. It really doesn't harm the 5er at all.
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 08-17-2013, 08:33 AM   #7
QCCowboy's Avatar
Completely agree on the JT Strong arms. I have had both and they are so much easier than the tripods.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 08-17-2013, 08:53 AM   #8
rattleNsmoke's Avatar
In the meantime, try not to extend the front landing gear too much. It's best to toss some blocks under them and only extend them a few inches. It will help make the trailer more stabile.
rattleNsmoke is offline   Reply With Quote
Old 08-17-2013, 10:51 AM   #9
Joel
Agreed that is does not harm the 5er but those inside may get seasick :-))
Old 08-17-2013, 10:05 PM   #10
Always Learning
JT's and between-the-wheel chocks help, but we still have a fair amount of movement. I tried the Valterra Stabilizer Jacks to no positive effect. My next plan is to get scissor jacks and put them near the axles.
http://learntorv.blogspot.com/2013/0...ilization.html
Unfortunately "just ignoring it" isn't an option as my mother-in-law frequently joins is and she has severe motion sickness issues. She's actually work her seasick wristbands for bed more than once before.
Old 08-21-2013, 09:48 AM   #11
I use the tripod on the pin and it works well for movement. Without it there was to much movement as we walked around. I had bought one from a fellow RVer at a camp ground for $50 and when that one broke, I got one from Camping World for about $150. It has been worth it for us. Good Luck
whj77372 is offline   Reply With Quote
Old 08-21-2013, 09:59 AM   #12
Wardell240's Avatar
Thank you guys you all have been a great help so many good ideas Thank you.
Old 08-21-2013, 10:11 AM   #13
another_newfie's Avatar
We will use a combination of JT's, or a similiar product and X-chocks. Combine that with blocks under the landing gear to prevent them from extending too much. Right now we only use standard wheel chocks as our mad money budget is a little tight and we definitely do feel the movement. Eventually I will also add a set of scissor jacks as well.
Then again I find after enough wobbly pops I hardly notice it...
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 08-21-2013, 10:15 AM   #14
SYE
SYE's Avatar
JT Strongarms!!!!!
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
SYE is offline   Reply With Quote
Old 08-21-2013, 10:38 AM   #15
jevanb's Avatar
we used the pin tri pod and I also put slide supports under the rear slides we can not hardly feel the kids at all. lots of people say dont use the slide supports but we always just take the pressure off with them, I also put 6x`s under the LDG and rear stabs
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 08-21-2013, 11:15 AM   #16
Most (if not all) manufacturers tell you not to use supports under the slides. If the RV settles a little after you put in the supports, you can severely damage the slide mechanism. They will usually void the warrantee.
Joel
Old 08-21-2013, 11:29 AM   #17
jevanb's Avatar
Joel
yea I know, but since the tires are sitting 2x10`s with 1/4 inch aluminun screwed to the bottom and the LDG is on a 2x10 and 6x6 plus the rear stabs are on 6x6 I think the trailer is not going to settle even if the tires lose air it is supported.
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
