Old 01-06-2014, 06:32 PM   #11
TURBS's Avatar
Originally Posted by wrvond View Post
To combine the topics of water filters and winterization, I'd like to take this opportunity to point out that there is a metal plate that can be installed in the housing when the filter is removed. This will block water from entering the canister area, which reduces the amount of AF required to winterize the system, and prevents freezing of the canister.
Or in a pinch take the wrapper off of a empty 20oz pepsi bottle tighten lid and put it in the canister upside down.
TURBS
golf cart safety instructor.
Old 01-06-2014, 06:53 PM   #12
Cyber Phrenologist
Radio's Avatar
We either lost or never had such a plate. So I took a rather skinny bottled water bottle and put that in there, reducing the amount of pink stuff in the canister by 75% or so. I put the filter in a zip lock bag and put it in the refrigerator.
Those filters are not RV specific, and you can get them at big box hardware/home stores like Home Depot. Just take your old filter with you. A cheaper filter seems to give us better flow and works just fine. If the CG water is really bad we put a Camco inline filter outside the camper.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 01-07-2014, 08:13 PM   #13
vasnipe's Avatar
Water filter Ft Pickens
Originally Posted by howellma View Post
I dont know I will find out in three weeks as we are headed back to fort Pickens. Though my wife sure has complsinef about the taste
My wally world culligan type filter worked just fine at Ft Pickens, no noticeable taste or odor in the coach. But then again I did not notice it in the shower house either... Great place to stay!
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is offline   Reply With Quote
Old 01-07-2014, 08:32 PM   #14
Originally Posted by bikendan View Post
yep, every new trailer with a water filter system that i've seen, doesn't have the cartridge installed.
mine had the cartridge and wrench in one of the drawers.
The last 3 new trailers we bought had filters installed and a spare filter, 2006 Kodiak, 2008 Flagstaff 831RLSS and the present 2012 Flagstaff 8528RKWS. Don't know if they were factory furnished and installed or dealer furnished and installed.
Old 01-09-2014, 07:48 AM   #15
Frank & Eve's Avatar
Thanks for that tip about getting the filters at the hardware store ! I've found them on line and 30 bucks seems high.
Frank & Eve is offline   Reply With Quote
Old 01-09-2014, 07:58 AM   #16
TURBS's Avatar
Ace hardware and true value is where I get mine.
There normally on sale in two packs in the spring and fall. "Cheap"
TURBS
Old 01-09-2014, 09:06 AM   #17
We bought our unit in the winter(Cold) no snow.The unit had (Air pressure) in the F/W lines.It maintained pressure so (No) leaks. Also no element in the Water filter,the element & wrench were in a kitchen drawer. When it was time to (Use) the unit we started to put water in the (F/W) tank and the (Covered Belly) started to Sag! Water running out everywhere! Dropped the rear elect.stablizer jacks,and the Complast Belly cover. The F/W tank had a (8in.Dia. Body grinder cut at the Sump area. Back to Dealer for Replacement F/W tank! Picked up after repair and went home for trip,NOPE! Water pump will NOT work,back to dealer,New Pump! The point is (Tank & Pump) cant be checked without (Fluid)! Youroo!!
youroo is online now   Reply With Quote
Old 01-23-2014, 02:52 PM   #18
I'm sure this has been addressed somewhere else, but this topic brought my question to mind. When we winterized the trailer, I removed the filter from the in-house filter system. Since we also use a separate filter outside the trailer when we hook up the water, is it necessary to put a new filter in the in-house system? Is it okay to just reinstall the plastic cartridge without the filter?
2012 Flagstaff 831FKBSS
2011 F250 Diesel
anitag is offline   Reply With Quote
Old 01-23-2014, 02:58 PM   #19
Ford Idaho's Avatar
It might cause a priming problem due to the extra air aside from that it should be just fine.
Old 01-23-2014, 09:15 PM   #20
Average Joe
MrJoe's Avatar
We've been running without a filter since we got the MH in October without a problem. I have the external filter for now. I'll try the internal one this Spring.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
water, water filter
