Old 02-25-2011, 06:53 AM   #31
Smokyroo's Avatar
We can do a full week without a problem. Some others pointed out some variables like is it winter or summer camping and so forth. We have battery operated head lights, and lanterns, use those instead of the trailer lighting. I brush my teeth at the bathhouse and not in the camper and use the restroom there and not in the camper...chances are if there is no electrical service at the site, then there is no water too.
I rely on the battery to help run the refrigerator and thats about it.
You could replace the interior lighting with LED stuff that is out today and you could save critical amps there.
Bob, Tonya and the kids
11 Rockwood Roo 233S
08 Grady White Seafarer 228
08 Tundra 5.7 liter 4x4 crew cab TRD limited
08 Toyota limited 4 Runner Iforce V8 full time 4WD, tow package
Smokyroo is offline   Reply With Quote
Old 02-25-2011, 07:14 AM   #32
MtnGuy's Avatar
Originally Posted by psmcn View Post
I think if I'm going to purchase a generator it will be either a 2000w or 3000w. I think 1000 is just not going to cut it. I have a friend selling a 3000w Yamaha quiet gen for $1300 and it only has about 100hrs on it.
If you are just going to charge the batteries, then you won't need a big generator.......the 1000 series should do it. That is plenty to plug up and use the converter to charge the battery.....but not much else. If you plan on using the onboard 12 volt charger, then that might made a difference, as the smaller units show an 8 amp charger, and the larger units at 12 amps....but it is a lot of weight to carry around with the larger units. You could always get a small battery charger geared to the amp battery you are trying to charge, and plug that into the 110 volt generator....in that case I would think that a 1000 watt unit should be a plenty.
Old 02-25-2011, 08:03 AM   #33
Herk7769's Avatar
99% of the time my Yamaha 3000 is "too much generator" for my needs. It loafs on idle most of the time. It will ramp up some for the coffee maker and Microwave just like a Honda 2000 (which screams like a banshee running a coffeemaker).
The OTHER 1% is why I tote that heavy sucker around. When I need AC; I need AC in a big way. It will dehumidify and air condition our camper and we suddenly become everyone's best friend when dry camping.
$1300 is a steal for a 3000 with 100 hours on the Hobbs meter.
HAM CALLSIGN - KC3FFW
Old 02-25-2011, 10:34 AM   #34
If the idiot lights are showing more of a dischargee then there really is, that is a good thing in my book. As mentioned before and I know, the lights are pretty much a joke. What is an inexpensive way to monitor the batteries more accurately??
I'll have to look at what my charger draws. the 1000w gen's weigh in at 29lbs the 2000 @ 75lbs and the 3000 at 130lbs all approximate but close. i don't know if i really need to carry around a heavy generator but as stated, when you want it its there to run the AC. I also founds a 2400 that is rated at 17.5 amps. enough to run the AC if needed and nothing else for a while and good for general use. Hummm choices, choices choices......
psmcn is offline   Reply With Quote
Old 02-25-2011, 12:48 PM   #35
Herk7769's Avatar
I saw the TM-2025 for $152.00 but you will still need the shunt and some wire. Easy install.
Old 05-02-2011, 04:49 AM   #36
Inverter
Has anyone ever Tried Hooking up a Inverter to the Battery and plugging a Battery Charger to the Inverter and Continuosly Charging the Battery?
Bad Boy is offline   Reply With Quote
Old 05-02-2011, 05:30 AM   #37
An inverter is about 60% efficient so you would consume more than you could produce.
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
Old 05-02-2011, 07:17 AM   #38
Herk7769's Avatar
I think the Amps lost due to wires, charger, internal resistance in the battery due to the high current draw and loss of capacity, and the inverter itself, would make it much worse than 60%. Most likely you would kill your battery in minutes; if not seconds.
The higher the current draw FROM the battery, the less capacity the battery has. This graph plots the loss in battery capacity due to amps out.
Name:	battery voltage and capacity Curve vs Discharge Rate.jpg
Old 05-02-2011, 07:29 AM   #39
KyDan's Avatar
Isn't this a twist on the "perpetual motion" question
that comes up every once in a while?
Did you take the bait
(ZZZZiinggggg, keep your rod tip up, tighten the drag,
play him!!)
Old 05-02-2011, 07:38 AM   #40
Herk7769's Avatar
I bit and had the hook in my cheek before I knew what hit me.
