Old 06-20-2014, 10:31 AM   #1
JoeR's Avatar
No hot water on Electric side
Surburban 6 gallon unit on my Windjammer. No hot water on eletric side, so the element has to be gone, right.
With much research here on replacing the hot water element, I found out that wasn't the problem. Bought the new element (Amazon) and 1 1/2 inch socket (Lowes has these BTW). Old element was a bit corroded but fine looking (no splits).
Anyway, back to research and found out about the hi/lo thermostats. I pulled the reset cover off the thermostats and sure enough, the fusible link was gone on the left side (AC thermostats). Right sided DC propane thermostats were fine with link in place.
So my point is don't assume you have a bad element just because your hot water heater won't work on electricity. A DVM check on the zero voltage across the element would have told me that.
So, now I have an extra (older) element, another thermostat on order for a backup and a lot more experience with Surburban RV water heaters.
2008 Toy Tundra DC 5.7L Bagged w/LTs
Hensley Arrow
2012 Windjammer 3001W, Atriumed
JoeR is offline   Reply With Quote
Old 06-20-2014, 10:40 AM   #2
Thanks for the reminder. My electric side of my water heater isn't working. I guess I ought to figure out why...
2013 Sabre 36QBOK pulled by a 2012 Ram 3500 DRW
Blogs: Learn to RV & Personal Fulltiming Adventure
Towing Calculators: Towing Planner
ependydad is online now   Reply With Quote
Old 06-20-2014, 10:56 AM   #3
fonzie's Avatar
When dealing with electricity, it is best to have a multi-meter and troubleshoot cause of malfunction before starting changing parts. It can get costly and frustrating chasing a ghost......
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 06-20-2014, 11:23 AM   #4
JoeR's Avatar
Uploaded a pic of the culprit.
Hensley Arrow
Old 07-05-2014, 08:15 PM   #5
kldenny's Avatar
On mine I found a small switch next to the element that was off. Turned on= lts of hot water.
05 Flagstaff 827 FLS pulled by an 01 Ram 2500 Diesel
kldenny is offline   Reply With Quote
Old 07-05-2014, 08:22 PM   #6
Cypressloser's Avatar
Still, you didn't have to pay somebody to find the problem plus you have spare just in case
2013 RAM 3500 Dually Longhorn
2014 Trilogy 3650RL, W/D, Onan 5500, 8000# Axles, IS, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
electric, hot water, water
