Old 12-20-2013, 01:00 AM   #11
OL Creeker's Avatar
DW tried an insulated bake sheet - no good.
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 12-20-2013, 07:32 AM   #12
WestCoastRV'er's Avatar
No More Burnt Biscuits
Originally Posted by RVChick View Post
If you always remember to line the outside of whatever pan you are using in the oven, in aluminum foil, it will not burn. I use my oven all the time in our XLR!
This was the trick I found to stop my biscuits from getting burnt on the bottom. Such an easy thing to do.
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 12-20-2013, 10:51 AM   #13
Frank & Eve's Avatar
Ok ya'll are saying to wrap the OUTSIDE of the pan with the aluminum foil not to line the pan with it ??
Frank & Eve is offline   Reply With Quote
Old 12-20-2013, 11:09 AM   #14
Phat Phrog
RVChick's Avatar
Correct! So if you have a cookie sheet, just tear enough foil for it to fit the bottom, and then to tuck up the sides. If its muffin tins, tear a piece to fit the bottom and again up the sides of the pan. By fitting it up the sides, it holds the foil in place while you put the pan in and out of the oven, plus it protects the sides of the pan from burning what's cooking inside. Hope that helps! I make cupcakes, and they turn out perfect! Set the oven to its proper cooking temp, and be sure to begin checking at the minimal time it's to cook. (If it says to cook for 10 - 15 minutes, begin checking at 10)
Kenny n Karen
TV: 2007 Chevy Silverado 3500 DRW - named Alice
RV: 2012 XLR Thunderbolt 35x12 - named Thor
RVChick is offline   Reply With Quote
Old 12-20-2013, 11:09 AM   #15
SSharp's Avatar
A little confused by this myself???
SSharp is offline   Reply With Quote
Old 12-20-2013, 11:10 AM   #16
Phat Phrog
RVChick's Avatar
Exactly! Plus you can reuse the foil for that pan, over and over!
Kenny n Karen
Old 12-20-2013, 11:11 AM   #17
Ford Idaho's Avatar
Yep, the OUTSIDE.
Old 12-20-2013, 11:25 AM   #18
Phat Phrog
RVChick's Avatar
One pic shows the foil around the sheet for biscuits, and I didn't take a pic of the foil wrapped cupcake tins, but you can see how perfect they baked up!
ID:	44000   Click image for larger version
Kenny n Karen
Old 12-20-2013, 12:44 PM   #19
Thanks for the clarification. Will have to try this next trip out !!
Old 12-23-2013, 09:17 PM   #20
Capsfloyd's Avatar
Wife bought a pizza stone , works good . Leaves it in the oven on the rack . Preheats the oven .. No problems
2009 Rambox crew cab
2012 831 Flagstaff RKSS
2010 jeep Liberty
2010 Harley Davidson Ultra Classic
Capsfloyd is offline   Reply With Quote
