Old 12-19-2013, 10:00 AM   #1
Frank & Eve's Avatar
No more burnt biscuits !
The first time using my oven I found out that it is nothing like a home oven. Checking in different forums, someone suggested placing a cooking stone on the floor of the oven. (The bottom of the oven just above the flames.) Found a pizza cooking stone at Wal-mart about 25 bucks. Placed it in the oven to try it out. Well it broke into 3 pieces as soon as it got hot but it worked like a charm ! It didn't effect it's ability to evenly distribute the heat even with it being broke !
Frank & Eve is offline   Reply With Quote
Old 12-19-2013, 10:04 AM   #2
The cheaper stones can do that if they heat up too quickly. But they do work rather well for that application.
jbrostek is offline   Reply With Quote
Old 12-19-2013, 10:36 AM   #3
I bought 4 square tiles from home depot (unglazed tiles), and put them in the oven too. They are cheap, I think it was just under $1 per tile. Still have to be careful and not cook things for to long in the oven.
Wildwood 26TBSS
Dodge Ram 2500 / Cummins Diesel
jrs_diesel is offline   Reply With Quote
Old 12-19-2013, 10:52 AM   #4
KyDan's Avatar
Someone suggested using one of those air insulated baking sheets
and I'm sure that would also help.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
KyDan is online now   Reply With Quote
Old 12-19-2013, 10:55 AM   #5
Zhanna's Avatar
I still haven't been brave enough to try the oven yet!
2005 Dodge Ram 2500, 4x4
2017 Heritage Glen QBUD312
Zhanna is offline   Reply With Quote
Old 12-19-2013, 11:06 AM   #6
The air gapped ones work ok, but I found the over still had some serious hot spotting issues. The baking stone evened out the heat enough to make it more usable.
Old 12-19-2013, 01:45 PM   #7
Great Horned Owl's Avatar
Instead of putting the stone on the floor of the oven, try placing it on the rack, directly under the baking sheet. Also, make sure that you preheat the stone along with the oven. So far, I have never broken one.
After some experimenting, I found a good way to store the stone in the oven while traveling. Cut four, 6" pieces from a pool noodle. Slit one side of each piece and slip them over the stone.
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 12-19-2013, 02:23 PM   #8
Habitual Camper-Fisherman
Chickenhawk911's Avatar
I couldn't find unglazed tiles in my area of Washington. Lowe's and Home Depot both looked at me as if I was crazy (DW says I am most of the time anyway so I'm used to it ). I settled on an airbake sheet that sits directly on the shelf above the burner. Made a world of difference. I found mine at Target as part of a two pack. The bigger one went into the house and the smaller one for this purpose. What a difference! Use the oven all the time with no fear now! Just be sure to preheat.
Chickenhawk911 is offline   Reply With Quote
Old 12-19-2013, 03:03 PM   #9
Phat Phrog
RVChick's Avatar
If you always remember to line the outside of whatever pan you are using in the oven, in aluminum foil, it will not burn. I use my oven all the time in our XLR!
Kenny n Karen
TV: 2017 Chevy Silverado 3500 LTZ - named Betty
RV: 2017 Columbus 366RL - named Karenís Camper
RVChick is offline   Reply With Quote
Old 12-19-2013, 03:07 PM   #10
I used an insulated cookie sheet under the pan for the cinnamon rolls and that worked great! Just think of the increase in gas mileage over a heavy pizza stone!
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is offline   Reply With Quote
