Old 06-16-2010, 02:16 PM   #21
powerboatr's Avatar
this sure makes the task of turning it and watching the picture go good to bad
in all my years i never thought any different until now
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 06-16-2010, 05:31 PM   #22
Grape Escape
And how does one know where the broadcast antennas are? This whole topic seems to be a waste of space. I have yet to see towers in any city. They are usually located outside in rural areas where land is cheaper. As far as I am concerned sometimes you get lucky and find good reception and many times not. Rotating via 360 marks on a protractor??
Nothing scientific about it. Raise the antenna up and point in some direction and when you get alot of stations fine tune it in which ever direction they come in.
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 06-16-2010, 05:45 PM   #23
MtnGuy's Avatar
I think the idea of this thread is to get the antennae aimed close to known towns and cities, do a scan, and then after getting the channel you can fine tune the antennae to get the best picture.
Old 06-16-2010, 05:56 PM   #24
Herk7769's Avatar
Smile That part is easy!
Just visit:
Address
Input your zip code (or address) and search!
A list of stations, compass heading and distance to broadcast tower as well as its most likely signal strength and channel.
The stations are ranked by ease of reception.
Easiest on the top; hardest on the bottom.
A map and a compass will get you the best reception possible in your area.
HAM CALLSIGN - KC3FFW
Old 06-22-2010, 01:16 PM   #25
skeeterbait8's Avatar
THANKS LOU!!!! Most times where I'm at I already have a good idea of which direction what major towns are. That I'm good at. It was finding out what part to point is what was getting me.
Official member of the "Roo Kroo"!
2009 - 4, 2010 - 135
2011 - 95 and counting
skeeterbait8 is offline   Reply With Quote
Old 06-22-2010, 01:32 PM   #26
MtnGuy's Avatar
On a related note, I camped at Loft Mtn. on the Skyline Drive over the weekend, and got 73 channels !!! Geez, that is more than I get on cable at home.
I do 3 channel searches with the antennae pointed approximately every 120 degrees.......seems to work well.
Old 06-22-2010, 02:00 PM   #27
At Cumberland Gap NHP I get two. 10.1(NBC) & 10.2(Knoxville weather).
Old 06-22-2010, 02:11 PM   #28
Herk7769's Avatar
The Internet widget
Works great. Still shopping for a circular protractor.
That mod is awesome.
Old 08-31-2010, 12:35 AM   #29
I'm considering adding the Wingman to the antenna on our Lexington, but if I do, it looks like the new extension will protrude over the edge of the roof by a good many inches when the antenna is down. To fix this, can the antenna be switched the opposite side of the mount so that the Wingman would then sit completely on the roof when lowered?
Cyberstork is offline   Reply With Quote
Old 08-31-2010, 06:03 AM   #30
jaxfl's Avatar
I have the Wingman extension and still if you are more than 50 miles from a tower, forget the TV and load the DVD. I just spent the weekend at Gamble Roger that is 30 miles from Daytona Beach and because it is a low area you get NO TV. Last month I was outside St Augustin Fl and because of heavy trees got no tv. Makes me made because at home I get more that 40 channels setting in the drive way.
jaxfl is offline   Reply With Quote
