01-10-2016, 12:41 PM
#21
I have a "W" and the outdoor speaker switch is the unmarked on / off switch on the side of the cabinet above the sink. Open the house door and look up and left and you should see it mounted there all by itself....
Wayne
2024 Sunseeker 2150SLEF / Ford E-350 Off-line 15 April 2024.
01-10-2016, 12:46 PM
#22
I will try to explain where ours is at. I have a 2400w. Step in on steps, turn left to face back of unit. Look straight up on side of upper kitchen cabinets, the end part. There is a weird black switch rocker looking thing. Says nothing on it or near it. Flip it the opposite way than it is now. That is the outdoor speaker switch. Drives me nuts. If u need me to go take a photo I can
01-10-2016, 12:54 PM
#23
Hilarious. I know the Jensen has at least a front and rear channel with a left and right on each. So how do you switch a left and right speaker both on or off with a single switch? One way is you wire both the right channel front into both interior speakers and the front left channel through the single switch, then to both exterior speakers. Works great but is 100% wrong
That's exactly what they did too, as the OP's comment about the exterior speakers going almost off if balance is biased fully to one side supports it.
So you have half of your music coming out of the inside speakers, and half comes out the outside speakers? They wire the travel trailers all wrong also. Maybe they should stick to building RV's and let a qualified audio guy wire up the sound systems? But hey they can't even build an RV all that great either
01-10-2016, 01:09 PM
#24
Jensen sterio
On my Jensen there are 3 buttons on the front A B C push C and the outside speakers are off.
01-10-2016, 01:18 PM
#25
Originally Posted by nomad297
I went ahead and sent a PM to JENSENRVDirect with a link to this thread, so hopefully he will chime in sometime soon.
Bruce
Thank you.
01-10-2016, 01:19 PM
#26
I have attached the FR Exterior Speaker Wiring Diagram for anyone who needs it. It looks like its wired correctly to me, but I don't claim to be an audio expert....
Wayne
01-10-2016, 01:23 PM
#27
Genius! We stupidly thought that was the switch for the porch light. We never use it so never tried it. THANK YOU, THANK YOU!!! All is well. No more sharing with uninterested parties.
01-10-2016, 01:24 PM
#28
Got it!!! Thank you.
01-10-2016, 01:33 PM
#29
Awesome! I'll share this with hubby who has an understanding of such things. Thank you!
01-10-2016, 01:35 PM
#30
Thank you everyone! This is my first experience using Forest River Forums. Very helpful! I'm sure I will return with more questions as we learn more about our Sunseeker. And maybe someday down the road, I can share something helpful.
01-10-2016, 02:04 PM
#31
mine is a IRV and has 3 buttons and also on remote. I have to shut off 2 & 3 every time I turn it on.
01-10-2016, 02:25 PM
#32
Originally Posted by brdeeee
The only buttons are for "eject," "GPS," and "source." Since the GPS/sound system is made for the vehicle, it seems the RV manufacturer should have installed something extra to control which speakers are engaged. I have seen others that have a simple switch mounted somewhere in the RV that controls A B C (or both.) We have searched high and low but found nothing so far. Thanks for help.
My Jenson had the ABC choice any or all at same time just like Bob said
2006 Gmc
2016 Forestriver Sierra 376 BHOK
Full Timers
Dick,
01-10-2016, 03:00 PM
#33
Citrus County, Fl.
Just a note to ad, that switch is no longer being used on the current 2016 model Forester/Sunseeker coming out of the factory since around August or Sept. They have gone to a different unit.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
01-10-2016, 03:30 PM
#34
I guess the only solution is to pull the unit out an cut wires and put in switches.
01-10-2016, 04:37 PM
#35
We have the 2290SF and have a switch above and to the right of the sink that turns the outside speakers on.
It is not labeled.
01-10-2016, 04:56 PM
#36
I would rewire the speakers. You should have stereo inside the unit and also outside. Use the Front Rear fader to turn off the outside or balance the sound between inside and outside.
B and B
01-10-2016, 06:53 PM
#37
I have 24 R and my outside speaker is on the side of the kitchen cabinet as your entering the coach
01-10-2016, 09:19 PM
#38
Look at the front of system and there should be 2 buttons A and B. A is for inside and B is outdoors. Just shut off the B button or push it in. Should solve the problem.
01-11-2016, 08:49 AM
#39
Our 2013 2400TS does not have outdoor speakers,,, but we do have a speaker switch neat the kitchen,,, I believe it is front - rear or all ??? It does not seam to work right anyway ???
01-17-2016, 05:24 PM
#40
Oh that it was that easy. Tried that, didn't work. Right/left balance almost worked but unacceptable solution. We think Forest River mistakenly left out the A/B switch.
any pictures of the front of unit
1 Surveyor
2015 Silverado Duramax w/Allison transmission
2014 surveyor 293RL fifth wheel
