Old 01-10-2016, 01:04 PM   #31
mine is a IRV and has 3 buttons and also on remote. I have to shut off 2 & 3 every time I turn it on.
NorSnrub is offline   Reply With Quote
Old 01-10-2016, 01:25 PM   #32
dicky1243's Avatar
Originally Posted by brdeeee View Post
The only buttons are for "eject," "GPS," and "source." Since the GPS/sound system is made for the vehicle, it seems the RV manufacturer should have installed something extra to control which speakers are engaged. I have seen others that have a simple switch mounted somewhere in the RV that controls A B C (or both.) We have searched high and low but found nothing so far. Thanks for help.
My Jenson had the ABC choice any or all at same time just like Bob said
2006 Gmc
2016 Forestriver Sierra 376 BHOK
Full Timers
Dick,
dicky1243 is offline   Reply With Quote
Old 01-10-2016, 02:00 PM   #33
Citrus County, Fl.
GL1800Rider's Avatar
Just a note to ad, that switch is no longer being used on the current 2016 model Forester/Sunseeker coming out of the factory since around August or Sept. They have gone to a different unit.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 01-10-2016, 02:30 PM   #34
I guess the only solution is to pull the unit out an cut wires and put in switches.
Old 01-10-2016, 03:37 PM   #35
We have the 2290SF and have a switch above and to the right of the sink that turns the outside speakers on.
It is not labeled.
Chief4774 is offline   Reply With Quote
Old 01-10-2016, 03:56 PM   #36
B and B's Avatar
I would rewire the speakers. You should have stereo inside the unit and also outside. Use the Front Rear fader to turn off the outside or balance the sound between inside and outside.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 01-10-2016, 05:53 PM   #37
I have 24 R and my outside speaker is on the side of the kitchen cabinet as your entering the coach
kimmie is offline   Reply With Quote
Old 01-10-2016, 08:19 PM   #38
justpassinthru's Avatar
Look at the front of system and there should be 2 buttons A and B. A is for inside and B is outdoors. Just shut off the B button or push it in. Should solve the problem.
justpassinthru is offline   Reply With Quote
Old 01-11-2016, 07:49 AM   #39
Wolverine 1945's Avatar
Our 2013 2400TS does not have outdoor speakers,,, but we do have a speaker switch neat the kitchen,,, I believe it is front - rear or all ??? It does not seam to work right anyway ???
Wolverine 1945 is online now   Reply With Quote
Old 01-17-2016, 04:24 PM   #40
1surveyor's Avatar
Oh that it was that easy. Tried that, didn't work. Right/left balance almost worked but unacceptable solution. We think Forest River mistakenly left out the A/B switch.
any pictures of the front of unit
1 Surveyor
2015 Silverado Duramax w/Allison transmission
2014 surveyor 293RL fifth wheel
1surveyor is offline   Reply With Quote
door
