Old 01-17-2011, 06:48 PM   #1
grhodes50's Avatar
Outside Caulking
I contacted Prime Time this morning with some questions about how the caulking should be applied to the outside running lights, etc... I received the answer this afternoon. Here is their reply;
The marker lights (clearance lights) are to having caulking on the top and on the sides, only the marker lights on the front cap will have the caulk all the way around them. The external speakers will not have caulking, only the putty tape underneath them.
There was no explaination as to why the caulking is done this way.
After Prime Time had sent me the same caulk they use when building their trailers I posted the brand on another thread. Here it is again, just in case;
Received the caulk today. 2 Tubes of Dicor Self Leveling Sealant for the roof and 2 tubes of TremPro 644 RTV Silicone.
It's made by TREMCO and they have 2 addresses, one in Ohio and one in Toronto. It states applications are for wood, porcelain, glass, metal, granite, corian and electrical insulation.
Hopefully this info will help some of you.
Gary & Trish
2019 Nights Camped - 3
Old 01-17-2011, 07:03 PM   #2
CampeRooo
rthrbelsewhere's Avatar
Good deal, I was just thinking about that today while we were enjoying the 50* degree weather. I have some areas above the windows where the caulking is starting to peel and figured it was about time to replace it all. Thank you for the reference. Bookmarked!
Where we've been:
2000 Rockwood Roo M-18 Hybrid
2006 Dodge Ram 2500 Auto 5.9 Diesel
Gone but not forgotten -1986 Rockwood 1003 PUP
rthrbelsewhere is offline   Reply With Quote
Old 01-18-2011, 08:16 AM   #3
MtnGuy's Avatar
Thanks for the info, Gary. I can understand the ideas behind their method. I think I asked the question on the other thread whether turbulence would force water from the bottom of the non-front cap marker lights.......guess not.
Old 01-18-2011, 08:59 AM   #4
KRS
KRS's Avatar
But it could drain out, I guess that's the thought process....
2004 Forest River Wildcat 29BHS
15.0 BTU ducted roof air
Tow vehicle: 2006 Dodge 3500 cummins turbo auto
Cummins exhaust brake
Air bags
KRS is offline   Reply With Quote
Old 01-18-2011, 09:12 AM   #5
MtnGuy's Avatar
Makes sense.
