Old 01-18-2011, 07:14 AM   #11
grhodes50's Avatar
Originally Posted by mtnguy View Post
OK, I gotta try this mod. Per chance, I have an extra string of rope lights in the basement.
mtnguy, I was thinking it was an old post of yours that I first read about this mod. Guess not.
I used the clear rope lights, but thinking about trying some blue ones.
Gary & Trish
2018 Nights Camped - 5
Old 01-18-2011, 07:20 AM   #12
MtnGuy's Avatar
I had posted a couple of times about using rope lights around waste tank drains during early spring and late fall camping to keep the pipes from freezing, but never thought to use the rope lights under the camper for accent lighting.
Old 02-02-2011, 11:02 AM   #13
itch'n to road trip
campnqueen's Avatar
Send a message via AIM to campnqueen Send a message via MSN to campnqueen Send a message via Yahoo to campnqueen
hhhhmmmm?...very interesting. I am a little confused. So the male plus end of the rope lights..it IS still attached to the rope light string? and you just zip ties it up to the frame also? Then when you park you just plug them into an extention cord?
2012 Ford F-250 King Ranch Super Crew Cab 4x4 "Mae West"
2014 Work & Play 25ULA "Ula"
Paula Drake, Ken Cooksey, Sunny Delight & Valor
Jasper Ga.
campnqueen is offline   Reply With Quote
Old 02-02-2011, 07:43 PM   #14
sherdep's Avatar
he is using a cut end from a cord to protect the plug while they are in travel and pull the old cord end off and then plug the lights into an exension cord.
the lights do not get hot enough to worry about catching fire.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 02-02-2011, 09:17 PM   #15
grhodes50's Avatar
Yeah, that's pretty much it except I have a rear kitchen model so there is a gas line running the length of the tt. I used zip ties to attach the rope lights to the gas line.
As sherdep mentioned, I used the female end off an old cord to use during storage and travel so that the male end on the rope lights doesn't get dirty or corroded.
Gary & Trish
