Old 10-13-2011, 08:39 PM   #1
wfmdfm's Avatar
oven use
We have tried a few times to use the oven. Each time the bottom is burning black. We have a thermometer on the rack to figure the temp. This last try was to broil and we had the same result. Are we setting it to high despite the thermometer reading?
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 10-13-2011, 08:44 PM   #2
Jeep4Two's Avatar
I've heard ovens are best performers as storage cubbies. Apparently burning as you describe is a common issue.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 10-13-2011, 09:05 PM   #3
Go out and buy yourself one or two pizza bricks or go to Lowes and get a couple of unglazed tiles and place then in the oven. It has helped hundreds to even out the temp swings and cook things perfectly.
Old 10-13-2011, 09:22 PM   #4
BRoss's Avatar
I was thinking of maybe putting the lid to my 10" Dutch oven in the oven in place of a tile.
BRoss is offline   Reply With Quote
Old 10-14-2011, 04:51 PM   #5
shineysideup's Avatar
I've cooked several things in my oven, never had a problem with it. I actually found myself wishing I had a gas oven in the house!
Is it missing something? My oven has a pan or plate that is over the top of the burner...
good luck,
shineysideup is offline   Reply With Quote
Old 10-14-2011, 05:11 PM   #6
We often use an air bake cookie sheet to help disperse the heat. Last year the DW did the Thanksgiving Dinner (I fried the turkey outside), including baking her famous, mouth watering, flakey crust apple pie. All came out just like cooking in the gas oven at the house.
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
