Old 04-14-2016, 06:07 AM   #1
Pallets on the roof ?
I'm looking for advice ? My 33' 5th. wheel is parked on wooded lot year round now under tall pines , Worried about coming back and finding limbs thru a leaking roof I'm considering putting wooden pallets on the roof as a buffer ? Any thoughts ? Thank you in advance .
LECTRICHUNTRMAN is offline   Reply With Quote
Old 04-14-2016, 06:13 AM   #2
B and B's Avatar
Hello Not sure how the roof membrane would stand up to this. Might consider a shed type pole and beam structure to cover the fifth wheel and slides to protect everything.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-14-2016, 06:14 AM   #3
CAT-RN's Avatar
As sure as I did something like that the limb would just miss the pallet and got thru roof anyway.
Don't see where a pallet would stop much. I just make sure I had good insurance.
Russell
CAT-RN is offline   Reply With Quote
Old 04-14-2016, 06:26 AM   #4
I would guess the amount of pallets required to cover your roof would weigh in the neighborhood of 650 - 750 lbs? And would probably have one heck of a lot of protruding nail heads and splinters that would easily put pin holes in the membrane.
This would be better
Mr Havercamp is offline   Reply With Quote
Old 04-14-2016, 06:49 AM   #5
Thx. , I have a rubber mat the size of the pallet to put under to protect the membrane . I appreciate your feedback.
Old 04-14-2016, 11:10 AM   #6
Sounds like a lot of weight to me.
Myrle is offline   Reply With Quote
Old 04-14-2016, 11:13 AM   #7
danny4127's Avatar
How about a carport like Carolina carports
danny4127 is offline   Reply With Quote
Old 04-14-2016, 01:03 PM   #8
You need the roof clear to promote the drying of it after rains, covering it with pallets or anything else, IMHO would trap moisture and promote mold and mildew.
Jim & Pam
Ram 2500, Crew Cab
2014 Hemisphere 327res
JP Camper is offline   Reply With Quote
Old 04-14-2016, 01:18 PM   #9
A pallet will not stop much of anything coming down and if something does fall on it the damage will most likely be worse vs. having no pallets
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 04-14-2016, 02:46 PM   #10
Canadian Member
itat's Avatar
I tend to agree with the other posters. Pallets could create a moisture problem and add a fair bit of weight especially went they're wet.
A proper roof structure is the best way to protect your 5er, but it wouldn't be cheap and you may or may not have the right to erect a structure. If it's not an option, hopefully you'll be able to keep the trees trimmed back sufficiently. I'm able to store mine at a cousin's farm in an open area away from trees.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
roo, roof
