Old 05-11-2014, 08:34 PM   #1
vasnipe's Avatar
Pay attention to your power pedestal
Looking over the threads recently posted I see ones questioning the need and the expense for power monitoring and surge units. I experienced the need for one this weekend at a big name campground in Natural Bridge Station, VA. We pulled in and the first thing I did was check the power at the pedestal. All appeared OK with the 30 amp service, but I noticed the connector box on the side of the box looked a little worse for wear. Got everything running and looked at my voltmeter inside the coach and saw 110 volts. OK, acceptable. Made some more preps to leave the unit to socialize and looked again at the meter. It was down to about 105 volts. Time to pull the plug. Touched the connector plug and it was hot to the touch. I checked the 50 amp service and it seemed OK, but I smelled hot wiring. I touched the connector box to the side of the pedestal and it was very hot. Not a good thing. Went to the office and they sent a tech over who pulled the cover, the attached photo is what he found. They moved me to another site and then took care of the power problem.
Hope this helps someone.
Chris in Virginia
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is offline   Reply With Quote
Old 05-11-2014, 09:06 PM   #2
Big Bad Allis's Avatar
Wow! Thanks for sharing. Hopefully everyone who's doubters take note.
Jason
2012 F350 SRW Powerstroke
2011 Acadia Denali
2014 Montana 356TBF
Big Bad Allis is offline   Reply With Quote
Old 05-11-2014, 09:12 PM   #3
davel1971's Avatar
makes me want to order a Progressive Industries unit right now. Sure don't want to fry my new 5th wheel
David & Lynn
Old 05-11-2014, 09:20 PM   #4
Looks like the smoke was let out!! Not good.
2003 Dodge Ram 2500 5.9 Diesel
2014 Rockwood 2608WS
Big Paul is offline   Reply With Quote
Old 05-11-2014, 09:34 PM   #5
Ret E-9 Anchor-clanker
donanddona's Avatar
Stayed at a RV park in MO. last year. A little cul-de-sac section. Didn't know it was on the older section. Three other family and friends came in the following day. First night was ok the next night our TV wouldn't come on. One cousin said his AC was sounding funny. We took voltage reading and yep 95 volts. Now we run a volt meter on the inside and on the outside to monitor daily...
donanddona is offline   Reply With Quote
Old 05-13-2014, 02:15 PM   #6
The secret to electronics is the little puff of smoke they put in each one. If you let it out, it quits working. ;-) :-P
Gene Failmezger
Sumter, SC
2014 Sierra 355RE
2014 Ford F350 6.7L diesel
GeneFail is offline   Reply With Quote
Old 05-13-2014, 02:18 PM   #7
TURBS's Avatar
Saved that picture!
TURBS
Sabre owners united!
Old 05-13-2014, 02:19 PM   #8
TURBS's Avatar
Your title should have sai
"This is why you need a progressive industries surge guard"
TURBS
Old 05-13-2014, 02:25 PM   #9
BamaBob's Avatar
We have one. I even use it when we are hooked up to shore power at our house!
On another power monitor thread, there is a good discussion on installing the in-line system.
Wish I had seen this discussion BEFORE I bought our portable one!
Installation of the Progressive Industries EMS
Oh, and Turbs is one of the guys who have done this install I believe...so over to you Ron
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 05-13-2014, 02:46 PM   #10
TURBS's Avatar
Easy peasy
TURBS
ID:	52320   Click image for larger version
ID:	52321   Click image for larger version
ID:	52322   Click image for larger version
power
