Old 10-14-2018, 12:11 PM   #1
Pink stuff for winter or not.
Iíve seen both suggestions. Does anyone know what the manufacturer suggests for the Rockwood Premier?
Divermom
Divermom3 is offline   Reply With Quote
Old 10-14-2018, 12:49 PM   #2
Flybob's Avatar
If you are in an area where it gets below freezing for any length of time. Then use pink stuff. Takes about an hour and is much less expensive than repairs. I doubt any manufacturer will recommend not using pink stuff in below freezing conditions.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-14-2018, 01:08 PM   #3
Scoundrel
HangDiver's Avatar
Antifreeze this Fall will help insure that you don't have to track down a leak next Spring.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 10-14-2018, 01:19 PM   #4
If the RV is also in New York, I would use Pink RV anti-freeze! Youroo! !
Old 10-14-2018, 01:40 PM   #5
Pink antifreeze is $2.50 a gallon here. Thatís pretty cheap insurance.
I blow out the lines and the suck in the antifreeze. Donít forget to blow out your black tank flusher.
Bob
HappyTrav is offline   Reply With Quote
Old 10-14-2018, 02:46 PM   #6
Broken Toe
Cowracer's Avatar
No pink stuff for me. Never have, never will. I blow my lines out and in roughly 15 years of doing so, we've never had a problem.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 10-14-2018, 04:08 PM   #7
bikendan's Avatar
Depends on where the RV is stored.
Where we live, blowing the lines out with air and antifreeze in the traps, is sufficient. We don't have hard freezes.
Apparently you live in New York, so you should definitely use antifreeze throughout the RV. Except the FW tank.
Equalizer WDH
Old 10-15-2018, 01:48 PM   #8
Tim
X2
latner is offline   Reply With Quote
Old 10-15-2018, 01:56 PM   #9
Tim
x3
Just got down to 15 degrees last night. Am I concerned? Nope. Just have to take your time and be thorough. I don't like the idea of antifreeze anything being anywhere around my drinking water system. But I am not knocking anti freeze. If that is the way you want to go, have at it. Personal choice. Whatever works for you.
joeuncool is offline   Reply With Quote
Old 10-15-2018, 02:03 PM   #10
Denver To Yuma In 90 Days
And except the hot water heater...
2015 Heartland Prowler P292 5'ver
2015 Chevy 2500HD 6.0L Gasser w/4.10 rear axle
"Just because someone has been "doing it for years with no problems" doesn't mean YOU should!"
JohnD10 is offline   Reply With Quote
winter
