Old 07-15-2013, 12:42 PM   #1
Plexiglass Screen Protector and Door Sizes
So, I finally got around to installing sheets of Plexiglas over the lower part of the door screens to prevent the dogs from damaging the screen. I know this has been discussed before, but it really was easy and inexpensive. Measure, cut, slide it in place, done. And the real fun part was to peel the paper backing off the Plexiglas of course!
For those who are going to do this, make sure you use a good quality, HIGH tooth count blade in your saw. This will ensure the cut edges of the Plexiglas are nice and smooth. If the blade doesn't have enough teeth, the edges will get dinged up and be rough.
I'm also glad I measured twice. The two doors on my trailer are different sizes. One of them is 2" wider than the other.
SCOC is offline   Reply With Quote
Old 07-15-2013, 01:11 PM   #2
Herk7769's Avatar
There is an inexpensive sheet plastic knife you can get at the same place you bought the plastic. Scribe several times and snap.
Red Devil 1170 Plexiglass Cutting Tool - Amazon.com
HAM CALLSIGN - KC3FFW
Old 07-15-2013, 01:25 PM   #3
B47
I don't know what your results were using this tool, but it has mixed reviews.
Old 07-15-2013, 01:30 PM   #4
Herk7769's Avatar
Actually the tool I used I could not find.
It was a buck, I think, and worked great.
Looked a lot like this one.
Plaskolite Cutting Tool for Plastic Sheets-1999999A at The Home Depot
Old 07-15-2013, 02:38 PM   #5
I didn't think about snapping it. If that produces good results, a utility knife should also do the trick then. I'll give it a shot on my next project.
Old 07-15-2013, 04:21 PM   #6
Herk7769's Avatar
A utility knife is not the same!
The blade in the Plexiglas knife is reversed (more like a plow). You drag it toward you and it digs a furrow in the plastic. Since you are pulling it it stays in the groove and you don't need to worry about losing fingers. The groove is wide and allows a clean snap.
A utility blade will be near impossible to control, will not cut deep enough without a million draws and the cut will not be as straight so lots of "planing" with a block plane. Also a good possibility the Plexiglas will shatter when snapped and my do THOSE cuts hurt.
Old 07-15-2013, 10:44 PM   #7
That makes sense. I don't have one in front of me to see, but I was browsing the reviews of one of those tools and I read a couple reviews that said a knife worked just as well. Your explanation does make a lot of sense though. I'll keep this in mind for when I need to cut some panels again. Thanks,
Old 08-28-2013, 04:58 PM   #8
katsmeow62's Avatar
We replaced the screen with plexi glass also. Hubby got tired of the dogs pushing out the screen. Works great!
2012 31RKOK Sabre 5th Wheel
2005 Dodge 2500 Diesel Pickup
2 spoiled rotten Chihuahuas, Ellie & Gracie!
katsmeow62 is offline   Reply With Quote
Old 08-28-2013, 05:04 PM   #9
Fulltime family RVer
I couldn't find the plexiglass cutter at my Home Depot, so a utility knife it was for me. BUT- I was only cutting straight lines for a bottom panel on my door.
I clamped a metal yard stick on top of the glass to my workbench and then used a utility knife against that. I cut a good 15-20 times before attempting to crack the edge. Worked nicely.
Old 08-28-2013, 05:15 PM   #10
Phat Phrog Stunt Crew
awwall's Avatar
This is the first mod I did after getting my MH home. I had a class C previously and the dogs tore out the screen. Like the OP, I used a small 6" circular saw I have had for many years, with a fine tooth blade. After cutting, I used a propane torch to clean up the edges. Gotta be quick with the torch, but it works great.
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
