Old 05-14-2014, 10:42 AM   #1
zs325RES's Avatar
'po-mans' home made stabilizer
Hi all,
I've learned so much from this forum, I though I would pay it back by sharing something I just made for my 5er. Inexpensive and very effective.
I wanted to eliminate the side-to-side sway up front that is typical for 5er landing gear. I know there are commercial solutions like the JT Strongarms and others, but I wasn't prepared to spend $300+ on a solution that I know I could work out myself.
I was stacking several pieces of 2X8 (5-6) under each landing gear foot to limit the extension, and that worked to a degree, but still was not as effective as I wanted it to be.
After a couple of attempts, I wound up with this.
For about $30 in parts (Menards) this eliminated all of the the side to side sway, and the trailer is now feels solid. I'm also using X-chocks between the wheels to control front to rear wiggle, which has never been much of a concern.
The trick is to make sure there is no axial play in the assembly. It is adjustable for any needed length with the use of the 1.2" threaded rod. Jam nuts tightened after adjusting the length, and snugging up the mount bolts at each end eliminate any play in the assembly.
It quite light too because I used 1.25" wood closet rod for the main rod. Wood??!! Yes, The only forces I needed to control is tension & compression and wood is a good material for this. Some good paint to seal it and it's good to go. I reamed out 3/4" bores in each end and glued 1/2" threaded couplers inside with JB Weld.
I mounted another simple L-bracket on top, under the front belly (you can see it in the top pic) so all I need to do is remove one side and swing it up for stowing. Everything metal is zinc plated, so protected from the elements.
This also allowed me to leave ~12 pieces of heavy board at home and opened up more front storage for better things.
Works great in the driveway and I'm looking forward to trying it during our camping trip next week.
Yeah I'm Dutch, but proud of it
2013 Crusader 325RES Touring Edition
2006 Silverado 2500HD LT SW ECSB, 6L LQ4/4L80E 4.10s w/16K Curt slider (not necessary), Air Lift bags & Black Bear Performance tune & CAI
Norm & Karen Zondervan
zs325RES is offline   Reply With Quote
Old 05-14-2014, 10:54 AM   #2
D-maxx dave's Avatar
I'm gathering parts now! That's cool!
David & Kelly
2015 Sandpiper 355RE
2015 Silverado 3500 CCSB SRW 4X4 D-maxx
Nights camped in 2016:03😄
D-maxx dave is offline   Reply With Quote
Old 05-14-2014, 11:05 AM   #3
SKnight's Avatar
Very cool! Are you finding the wood rod working better under tension or compression? I'd imagine tension, but I would wonder about my inserts pulling out.
Old 05-14-2014, 11:13 AM   #4
Fulltime family RVer
What is your setup/breakdown like with this?
ependydad is online now   Reply With Quote
Old 05-14-2014, 11:26 AM   #5
Is one brace enough?
David & Kelly
Old 05-14-2014, 11:31 AM   #6
TURBS's Avatar
Looks familiar.
My setup with cargo jacks from Midwest wheel .
$60.00 invested and I can tighten and loosen with the handle.
TURBS
Sabre owners united!
Old 05-14-2014, 11:34 AM   #7
TURBS's Avatar
Few more.
All I have to do to setup is ratchet lever till tight.
Tear down involves flipping the safety catch and releasing handle
TURBS
ID:	52391   Click image for larger version
Old 05-14-2014, 11:56 AM   #8
zs325RES's Avatar
Both actually. The JB Weld is tenacious. I ground some lateral grooves into the couplers which 'grab' the JB weld. I don't expect them to pull out.
Pretty easy - just remove the lower mount 1/2" bolt, swing the rod up and reinstall the bolt into the top bracket. I do need to hand screw in/out the end so it it the correct length, but very simple.
The wing nuts allow reasonably tight hand tighten, but I might keep a 3/4" open end wrench handy to snug up the bolts and jam nuts.
Yes - one bar handles both the tension and compression....just like Turbs does.
Old 05-14-2014, 05:06 PM   #9
Thanks!
David & Kelly
Old 05-14-2014, 06:15 PM   #10
TURBS's Avatar
Just for comparison. ...
1) cut cargo bars to length.
2) welded a internally drilled and tapped slug into each end.
3) screwed in heim joints and locked them down.
4) made two mounting brackets.
2 cargo jacks
4 heim ends
4 solid slugs
Misc metal for brackets
I just now realized my powder coating neighbor has never called me to finish..... hmmmm phone call time.
TURBS
ID:	52446   Click image for larger version
ID:	52447   Click image for larger version
ID:	52448   Click image for larger version
