Old 08-08-2015, 05:13 PM   #11
DNBINFV's Avatar
Love all the ideas,
Donna and Bob (retired USAF),
fur babies Casey (mix), Lucy and Loki (standard poodles)
had a 2015 Rockwood 8281 WS - traded for another brand.
2016 RAM 3500
DNBINFV is offline   Reply With Quote
Old 08-08-2015, 06:06 PM   #12
mike.t's Avatar
Thanks. I'm on it. With my set up i can also put one at the other end to cushion it if it slams shut.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 08-09-2015, 07:27 AM   #13
Wolverine 1945's Avatar
If your Pool Noddle is to large you can use Pipe Insulation !!!
I keep a couple of different sizes around all the time !!!
As for the Microwave turn table,,, we remove the glass dish,,,
and put it in the towel drawer !!!
Wolverine 1945 is offline   Reply With Quote
Old 08-09-2015, 09:36 AM   #14
mike.t's Avatar
Also good idea Wolverine the color is a plus.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 08-09-2015, 10:26 AM   #15
Islander's Avatar
It is kinda nice to come across an inexpensive fix for a lot of things...
...and for me pool noodles are #1.
By cutting a single slit, down to the center hole, allows you to attach them to items like lawn chairs to prevent chafe while stored under way.
I also use it for the items I lash down in the bed of the truck not only for chafe/protection but to stop any noise from the road bumps etc.
I use all sorts of shapes and pieces inside the RV to fill gaps in the draws and cupboards ... even for the furniture when it is lashed down for travel.
For any one using a ladder on or around their RV the pool noodle makes a fantastic "non marring" padding attached to the end or where the ladder touches the RV....again...just cut a slit and it will fit most ladders.
Cut to fit....it is quite popular to put on the corners of the slide outs to prevent head bumps...even down low for the kids height.
Speaking of 'head banging'... I found that the 3/4" pipe insulation fits nicely on the front landing gear drive shaft of 5th wheels, for those of us that have it running through the front storage locker.
I always carry some extra pieces of pool noodle in the storage areas...it is just too darn handy !
Hope this helps
Islander
PS "Radio".... Loved the door stop idea
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles
Edge programmer, 4" SS exhaust turbo/back,
Tru-Cool Max Trans Cooler, Bilstein Shocks
Vancouver Island, B.C., Canada
Islander is offline   Reply With Quote
Old 08-09-2015, 07:49 PM   #16
Originally Posted by Radio View Post
I have repaired the travel safety strap on the bedroom pocket door several times. The slight movement it allows lets the door bump against it during travel. Eventually this constant bumping damages the strap.
So I used a bit of pool noodle to make a door stop. Jammed in there snuggly, the door will not move.
On my Sunseeker the door is close to awning arms cut a piece of noodle about 16" long then split it so it fits over the arm. Also take noodle pieces about 12" long 45 them and put them on corners of slides saves head bumps.
Myrle is offline   Reply With Quote
Old 08-10-2015, 06:23 AM   #17
Sounds to me like Pool Noodles are used every where,,,
except maybe in a pool ???
LOL !!!
Guess I better pick up a couple,,, for when my pipe insulation is to small !!!
Old 08-16-2015, 06:47 AM   #18
Cyber Phrenologist
Radio's Avatar
Update...
Pool noodles, I have discovered, do not like to be under compression. In the door stop and the microwave application the noodle is under compression. They will loose their "springy-ness" rather quickly.
So when you get home, take the noodles out. Don't leave them compressed while the camper is not in use.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
door, pool noodle
