Old 02-24-2016, 12:31 PM   #1
CWSWine's Avatar
Power Cord Reel
Just added a reel to hold my power cord and it save space. Might need a little more practice getting rolled up a little neater.. Got mine from Amazon but it carried a lot places.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 02-24-2016, 12:37 PM   #2
rracer5's Avatar
Those 50 amp cords can have a mind of their own. And, if it's cold out you would have had to letter in High school wrestling to get wound up!.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 02-24-2016, 12:42 PM   #3
CWSWine's Avatar
It was about 30 degrees when I rolled up and it wasn't bad and that part of the reason it looks like it does. Just had to lay out the cord so went straight into the real and not off to one side. If it less than 30 degrees I probably won't be camping.
You could also buy the powered one for 599.99 and that would solve the problem reeling it in.
Old 02-24-2016, 01:06 PM   #4
Fulltime family RVer
My dirty little fulltiming secret is that I now just throw the cord in the bed of the truck!
ependydad is online now   Reply With Quote
Old 02-24-2016, 01:21 PM   #5
rracer5's Avatar
Ha, ha, ha....me too since I'll be plugging it back in in a few hours!!!
2014 Sanibel 3250
Old 02-25-2016, 09:45 AM   #6
Broken Toe
Cowracer's Avatar
That tight of a coil will play hell with the life of that cord.
The absolute best way to wrap up any cord is called the "over under" method. Every single cord and hose I have gets wrapped this way including my shore line. It relieves stress on it as the turns in effect go both ways. But the biggest advantage is it will never knot up. I can take my 100 foot, 10ga extension cord, drop the coil on the ground, grab the proper end, walk away and pull the entire cord out without a single tangle or knot
This video shows the technique. Its on a video cable, but it works the same. Theres a bit of talking, the good stuff starts at about 1:25
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is offline   Reply With Quote
Old 02-25-2016, 10:05 AM   #7
dieselguy's Avatar
Everyone has different ideas on their own mods to their RV. My Silverback came with one of those cord reels in the main storage bay and it was the first thing I removed. Takes up too much space and too user unfriendly during my couple of times using it. I'm a truck bed cord holder kind of guy as well. You seem happy with it so far.
dieselguy is offline   Reply With Quote
power
