Old 09-21-2012, 12:55 PM   #1
power question??
Hi, guys. I just bought a travel trailer and, although I've turned everything (I think) off, the battery goes dead. I'm brand new to tt's and I'm wondering if anyone has any ideas either why it goes dead or maybe what I'm missing when I close it up. It's really getting to me. Thanks for the read and any and all responses. Rick
2004 GMC Safari XLE
2009 Flagstaff 18FBRS MicroLite
sidecar is offline   Reply With Quote
Old 09-21-2012, 01:38 PM   #2
wmtire's Avatar
There are several things in an RV that will continue to slowly drain the battery even when you think everything is turned off. One of the leading culprits for battery drain is the LP gas leak detector. On a lot of RVs this is designed to operate all of the time. There are other items that we overlook sometimes like the power booster on the TV antenna, or a clock that operates off of 12 Volts. If your RV is not equipped with a battery disconnect switch you can purchase a device that installs right on the battery post. When you're not using the RV you simply lift a lever up and it disconnects all 12 Volt power going to the RV
This tip contributed by Mark Polk at RV Education 101
2011 Flagstaff 831 RLBSS
Old 09-21-2012, 01:45 PM   #3
Triguy's Avatar
Yep - its the parasitic drains. Quite a few of them in most trailers.
You can buy an "on-off" battery disconnect such as the Blue Sea 6006m or one that allows you to select battery bank 1 or battery bank 2, or 1+2. If you know you will add a second 12-volt, than buy the Blue Sea 9001e.
This is the 6006m
I will also add that you might have damaged your current battery if it had been discharged too low and it might not hold a charge anymore.
You can test it various ways yourself or take it to a battery place and they'll test it for you.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 09-21-2012, 01:45 PM   #4
I am hardly a Jr. Camper
Another item that will drain the battery is the refrigerator. Even thought it is on gas or 120v the brain of this unit is operated with 12v.
It's great to live in a Campground/Rv Park!!
serengeti is offline   Reply With Quote
Old 09-21-2012, 04:05 PM   #5
Thanks, guys. Mark, I just came back from Princess Auto and bought a battery disconnect switch. I didn't even know there was such a thing. Again, thanks.
2004 GMC Safari XLE
