Old 04-01-2019, 12:26 PM   #1
Propane hose with tank cover
Probably a no brainer.... I just purchased a propane tank cover and was wondering where people put the tank connection hose (since it will not allow the tank cover to go on.) Do you just let it dangle, cable tie it to something, completely remove it, make a cutout in the tank cover, etc.....??
nhpfood is offline   Reply With Quote
Old 04-02-2019, 08:31 PM   #2
larry2c's Avatar
Is this cover for your frame mounted propane tank or a "free standing" tank? I have two 20# tanks on my TT and the cover slides over with no issue. The hose is routed downward so it does not interfere with the cover.
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Only one shedding mutt now RIP Yoshi
larry2c is offline   Reply With Quote
Old 04-03-2019, 07:51 AM   #3
It is the tank it came with on the front (a single tank). It has a bracket holding it to the frame. The line from the TT comes straight across to the top of the tank and hooks on. The line isn't long enough to go down and up from the bottom of the cover.
Name:	tank cover.jpg
Old 04-03-2019, 07:56 AM   #4
Mopar Guy
you could get a propane extension hose. and then run it down and back up
Or get a longer feed hose that allows it to down and back up
Dave
2019 Grey Wolf 24JS- sold
1998 Holiday Rambler Imperial 41wds
Cost4133 is offline   Reply With Quote
Old 04-03-2019, 08:00 AM   #5
That might be the easiest way to go. Thanks for the advice!
Old 04-03-2019, 01:44 PM   #6
My regulator sits much closer to the tanks. The cover fits over everything. Maybe you could modify the bracket to do this.
bbbymac is offline   Reply With Quote
Old 04-03-2019, 01:49 PM   #7
Trailer Park Supervisor
NJKris's Avatar
Surprised Forest River didn't give you enough slack to put the regulator beneath the cover. I have the same cover on my trailer, but for double tanks. The switch over regulator all fits beneath the cover.
Yes, I drink the water!
NJKris is offline   Reply With Quote
Old 04-03-2019, 05:00 PM   #8
I bet if you unbolted the regulator from the trailer wall, you could snake it under the tank cover and bolt it to a frame piece. Nothing to buy.
cover, propane, tank
