Old 05-31-2013, 05:28 PM   #11
As usual, there are arguments both ways, the chance that the frig will try to ignite while at a gas station are remote, plus the fact for gasoline fuel, the stoichiometric air/fuel mixture is approximately 14.7 times the mass of air to fuel. 7% gas, 93% air. This may seem like an easily attainable amount of vapors but in fact it is unrealistic and requires an enclosed environment to achieve this kind of ratio. As stated above, gasoline vapors are 14.7 times heavier than air and will immediately sink to the ground and a refrigerator igniter is approx. 3' plus above the ground.
Those that believe in turning off the propane or refrigerators will continue to do so and those that don't believe in turning either one off will continue to leave them on.
With the thousands and thousands of campers traveling with the refrigerators on, we should be inundated with newscasts and videos of campers exploding at gas stations, in 73yrs, I've never seen even one.
Old 05-31-2013, 05:48 PM   #12
Denver, CO
garbonz's Avatar
X2. Especially diesel, but watch out for the guy next to you.
2017 Fuse 23T
Old 05-31-2013, 05:51 PM   #13
Plus, the refrigerator is 25'-40' from the gas pump.
Old 05-31-2013, 06:17 PM   #14
Somewhat right of center
Crabbyguy's Avatar
The chance at being struck by lightning in a year are around a million to 1, but I'm not about to push it by running around with a metal pole in a thunder storm. Please, turn of any ignition sources when fueling up, especially if you have loved ones with you. Safety is more important than cold beers. Well, maybe not.. and yes it has happened. Gas vapors, ignition source, fire, camper burns up, fire impinges on propane tanks, relief valve starts screaming flame or worse.....KA-BOOM! (BLEVE) Was a cold fridge worth it? Even better, fuel up before hooking up.
Crabbyguy is offline   Reply With Quote
Old 05-31-2013, 06:34 PM   #15
ernest917's Avatar
Is there a need to turn off fridge if your running a diesel MH and filling with diesel.....
ernest917 is offline   Reply With Quote
Old 05-31-2013, 06:52 PM   #16
Crabbyguy's Avatar
I see your point since diesel has a much higher ignition temp but I wouldn't chance it since there are usually gas pumps close by. Gas vapors can travel considerable distance and "puddle" in low lying areas. All I'm saying is why risk it? It may be rare but it certainly isn't impossible.
Old 05-31-2013, 06:59 PM   #17
ernest917's Avatar
You are correct.....
Old 06-01-2013, 10:43 AM   #18
Explorer
if I ever pull into a fueling station and smell so much gas that there could be an issue, I will move on and call 911. Could always up grade to a 3 way fridge(propane,120AC and 12DC).
Every one should be safe and think of others
John
John
2011 Wildwood T26BHXL
2004 Yukon XL Denali
43yrs of camping; one lucky guy
YoungKopernik is offline   Reply With Quote
Old 06-01-2013, 10:50 AM   #19
Sure hope you don't stop at a station with another camper fueling because his frig is probably on.
Old 06-01-2013, 11:05 AM   #20
MotocrossCamper's Avatar
If you see a Sunseeker pulling a 16' enclosed motocross trailer, I know for a fact his is on.
MotocrossCamper is offline   Reply With Quote
