Old 05-12-2011, 10:57 AM   #1
grhodes50's Avatar
Protect All
Has anyone used this product? If so, how do you like it?
My brother told me about how he liked this product, so I ordered some and received it the other day. I went out and spot tested it on the trailer and it was easy on & off. I did like the results. As in the name, you can use it on any surface, glass, plastic, metal, fiberglass, etc....
So I was wondering if any of you have used it and how you like it.
P.S. I know there are other great products out there, but I am really only interested in what people have to say about this particular product. I'm not meaning to start a product war. Thanks
Gary & Trish
2019 Nights Camped - 3
Old 05-12-2011, 11:11 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
I've used it and had good results. Only issue I had was the pump didn't spray the product out very well. I won another bottle at a RV Seminar and that one worked great so I'll just transfer the pump when I use up the first bottle.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 05-12-2011, 11:16 AM   #3
grhodes50's Avatar
Thanks, Charlie.
Compared to a regular type wax, how long does it seem to last?
I went ahead and bought the gallon size. I am intending to use a spray bottle I have at the house. Hopefully it won't clog up.
Gary & Trish
Old 05-12-2011, 11:28 AM   #4
cfsoistman's Avatar
Originally Posted by grhodes50 View Post
Thanks, Charlie.
I haven't used it on the motorhome's finish outside, only inside on cabinets etc. However I did use it on our 2001 Hybrid and the shine lasted all season and made washing it pretty easy. If you use a black streak remover you'll need to reuse the Protect-All on that area. Just remember to shake the bottle before using it.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 07-03-2011, 11:31 AM   #5
rohlingerrv's Avatar
I just used protect all for the first time and I love it! Best part its for everything, most waxes hurt decals and my camper has a lot of decals so I was having to wax around them which was a pain.Its easy to apply and easy to remove, Anything that can cut down the time waxing and cleaning a big 5th wheel is the product for me.
rohlingerrv is offline   Reply With Quote
Old 07-03-2011, 12:04 PM   #6
grhodes50's Avatar
It's been about a month since I applied the Protect All to my tt. I was washing my tv this morning and decided to rinse off the tt. The tt shed the water right off. Dirt, bugs, etc... came off pretty easy. Some of the bugs took just a little scrubing, but did come off easier than usual.
So, so far, so good!
Gary & Trish
Old 07-03-2011, 12:23 PM   #7
I recently treated the exterior of my Sunseeker 2300 with Protect All. My method of application: put old sock on hand, spray Protect All liberally onto sock, apply Protect All to previously washed surface with circular motion, wipe dry immediately with clean cloth. The residual is very easy to remove with the clean cloth.
Not only does this product produce an even wax finish, but the wiping with the clean cloth removes a surprising amount of remaining surface grime. I was also pleasantly surprised at how easy it is to get a uniform-looking application without any obvious gaps or over-treated areas. One factor that prompted me to try this product is the inclusion of a UV blocker which will provide some protection from sun exposure.
I purchased a 32 oz. spray bottle and used only approx. half of it to treat my Sunseeker – including the cab and roof. From my experience, I give the product a positive recommendation.
Al Fresco is offline   Reply With Quote
Old 07-03-2011, 12:41 PM   #8
grhodes50's Avatar
I also used the Protect All Rubber Roof Treatment. Here's a link to a thread I started with pics; http://www.forestriverforums.com/for...ent-13764.html
Gary & Trish
