Old 05-15-2018, 07:55 PM   #1
jdstrubel's Avatar
Putting Slides in when raining
Hello all - it has been alittle while since I've been on. Hello and safe travels this season.
We are getting ready to head out for our first trip of the season. I have a question I never really worried with on my previous TT because it only had 1 slide.
But now I have 3... What do you do when putting slides in during the rain. How to you try to get as much water off as possible before the slide goes in? We do have slide covers.
Do you use a squeegee... Would appreciate any tips.
Thanks and Happy Trails!
Debbie
2017 Flagstaff Super Lite - 832IKBS - Diamond Package
2006 GMC Sierra 2500HD
Been an RV owner since 2003
jdstrubel is offline   Reply With Quote
Old 05-15-2018, 08:00 PM   #2
If you have slide toppers then the amount of water will not be noticed.
donniedu is offline   Reply With Quote
Old 05-15-2018, 08:01 PM   #3
slide them in with a few junk towels laying around to soak up any access water. your slides should be triple seal with sweep type seals. most access should come off on the way in especially with toppers.
Kimber45 is offline   Reply With Quote
Old 05-15-2018, 08:27 PM   #4
Most of the time I will nose the camper up or down a little and pause the slide when retracting to give the water a chance to run off. If it's not raining I use a cordless blower to blow the water off.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 05-15-2018, 08:52 PM   #5
Always Learning
With slide toppers, we've always just ran the slides in with no thought to the water on top. Just today they were heavy with water and it ran off the slide as we retracted them.
Old 05-15-2018, 09:03 PM   #6
themounties's Avatar
Same here, we have always just ran the slides in and never seen any water inside.
2003 Duramax
2010 Blue Ridge
1 DW
1 mutt
on occasion 1 DD
themounties is offline   Reply With Quote
Old 05-16-2018, 03:52 PM   #7
Pockets
Plus you will notice that when the slides start, the bottom comes in first for an inch. Leaves the top of the slide at an angle tilting out. Water will tend to drain towards the wall. Then the seals sweep the water out. You may notice a little water on the sides inside. A rag will sop that up in a jiffy.
Bob & Kelley
2015 Flagstaff 26RBSS
2014 FORD F-150 Supercrew XTR 4x4
3.5L Ecoboost, 3:73 axle, Max Tow Pkg 2015(36 nights) 2016(74 nights) 2017(174 nights) 2018(157 nights) 2019(79 nights) 2020(108 nights)
Pockets is offline   Reply With Quote
Old 05-16-2018, 04:15 PM   #8
cordless blower
I always carry a battery operated blower to blow off the slide tops. Weather it be leaves, pine needles, water. I like to slide tops cleared off before retracting. And the blower comes in handy to blow off tables, patio slabs.
David Cournoyer
2015 F250 SRW 4x4 Crew Cab Platinum
6.7L Powerstroke V-8 Diesel
2013 Rockwood Windjammer 3001w Diamond
Handydc is offline   Reply With Quote
Old 05-16-2018, 05:08 PM   #9
ARLO
Absolutely nothing. The amount of water is very minimal. I have never seen any water.
rlocicero is offline   Reply With Quote
Old 05-16-2018, 05:41 PM   #10
Homebrew's Avatar
I agree, very minimal just pull the slides in when you leave .
Good idea about tilting trailer before hooking up. I tilt the trailer to get the cycles before hooking up , any rain water left on the slide is minimal.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 05-17-2018, 03:22 AM   #11
Global Nomad
Scheinin's Avatar
We have been full timing for 2 years, in all sorts of weather. We have slide toppers on our 3 slides. Since the toppers roll "outward" we have no problem with water and debris (leaves, small tree sticks) rolling off as we retract. Periodically I check the slide tops when they are in, and have never found water or junk on them.
Steven J. Scheinin
2015 RAM 3500 4X4
6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS (Center Kitchen Three Slides)
Scheinin is offline   Reply With Quote
Old 05-17-2018, 05:20 AM   #12
We never put slides in due to rain. No issues so far in 7 years.
04 Ram 3500
07 Ram 3500 X2
10 Ram 3500 Laramie
2011 Puma 295kbh
larryo is offline   Reply With Quote
Old 05-17-2018, 05:37 AM   #13
Same here, as far as just pulling slides in. We camped this past weekend and it rained all weekend and when we pulled the slides in the rubber seals seemed to work very well as a squeegee because as it was going in the water was pouring off the sides of the slides. Once we get home we usually open everything back up to dry everything out. I think more important than worrying about very minimal water from slides is having a good dehumidifier or at least having some of those Damrid's out.
2016 F250 Super cab long bed
2018 Rockwood 8327SS
Briyoung is offline   Reply With Quote
slide
