Old 12-18-2013, 09:57 PM   #21
RKR
RKR's Avatar
Personally, when I did research to decide on what to replace my tires with- it was either Goodyear Marathon or Maxxis m8008. I opted for the Maxxis, but would have been happy with either.
I ordered mine from discounttiredirect.com and took them 2 by 2 into a local tire shop for mounting (and should have had them balanced but got talked out of it).
Hey Ependydad, I'm just curious about what the tire shop told you to talk you out of balancing your tires ?
RKR is offline   Reply With Quote
Old 12-18-2013, 10:00 PM   #22
Always Learning
Just that trailer tires typically aren't balanced and 2 of the guys made a big deal about it needing 3.5 (something) of weight. They said it was a lot to hang off of a tire.
However, it was a Merchant Tire kind of place who typically do passenger cars and light trucks, so they were definitely out of their element.
But, I also wasn't informed enough to tell them to do other things to achieve balance or to tell them to go ahead anyway. Next time I'll take the tires to a truck shop or trailer place.
Old 12-18-2013, 10:37 PM   #23
I suspect whomever it was, they just didn't want to balance them. I've never been to a tire shop that didn't suggest balancing all tires. It's just common practice at most reputable shops. Tires need to be balanced to get optimum wear and minimize undue wear on the vehicle suspension.
Old 12-18-2013, 10:41 PM   #24
rattleNsmoke's Avatar
I've had tires requiring A LOT of weight to bring them into a balance. The tire guys simply re-broke the bead and spun the carcass around on the rim 180 degrees and Voila! they balanced up perfectly with very little weight. No biggie.
rattleNsmoke is offline   Reply With Quote
Old 12-18-2013, 10:49 PM   #25
X2, and 3.5 oz is not too much wt to hang on a wheel, altho if they had broken the tire down and rotated it like rattleNsmoke suggested, it probably would have taken a lot less. As for the shop being out of their element on trailer tires, the tires/wheels are similar to cars and light trucks. They just didn't want to balance them IMO.
Old 12-18-2013, 10:51 PM   #26
Always Learning
As I said - I was out of my element with it all and couldn't stand to make an argument either way.
Old 12-18-2013, 10:58 PM   #27
Just a suggestion, even tho it might be a PITA, I would make a point of taking the trailer to a shop and have them balanced. Good tires like you put on are too expensive to have them prematurely worn out from cupping from being out of balance. A good estimate would be the life would be reduced by @ least 25% or more.
Old 12-18-2013, 11:25 PM   #28
Always Learning
That's a thought I've had. I'd actually like to find a truck place that can take care of it all at once without making 2 trips (doing either side at a time). There's a truck stop up the road that I'll call come spring.
Old 12-18-2013, 11:42 PM   #29
dcheatwood's Avatar
My 2005 Jayco came with Maxxis. Towed more than 25,000 miles in 5 years. No flats, no uneven wear. Sold it with original tires. My 2010 wildcat came with 10 ply Trail Express. 3 out of 4 blew out from 1500 to 4000 miles. 4th tire was about to blow but I saw the tread separating.
2018 Forester 3011 DS
Old 12-19-2013, 01:09 AM   #30
RKR
RKR's Avatar
10-4 , I was just curious. Thanks
Old 12-19-2013, 01:17 AM   #31
RKR
RKR's Avatar
That's for sure. I worked at a tire shop when I was younger back in the 80's and that how we were trained when a tire took a lot of weight.
Old 12-19-2013, 07:00 AM   #32
Herk7769's Avatar
Not a tire guy, but my Marathons were balanced and required very little weight. My truck tires have bigger weights.
I seem to remember someone here saying that you can not use the center hole (common practice at most garages) to center the wheel on the spin balancer. There is a "spider" looking adapter that goes into the stud holes that must be used. It is a PITA to install and many garages that mostly do car tires won't take the time.
I will try to find the thread, but it was some time ago.
ID:	43943   Click image for larger version
ID:	43944   Click image for larger version
ID:	43945   Click image for larger version
ID:	43946   Click image for larger version
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 12-19-2013, 07:35 AM   #33
amxpress's Avatar
Steel trailer rims require using a finger adapter when mounted on the tire balancer. They are stud centric, using the studs to center the rim on the axle. The rims are stamped steel and their center hole is not necessarily concentric. Reputable shops that do tire work should have these adapters, if they know how to use them is another question.
Aluminum rims can be balanced without the adapters as their center hole is concentric due to the manufacturing and machining process; however, if it's a large rim, i.e.16", it would be wise to use the adapter to provide better support when the rim is mounted on the tire balancer.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 12-19-2013, 08:51 AM   #34
ryand's Avatar
Not to beat a dead horse, tons of threads about the OEM tires offered on new units. IMO it is a problem that could be avoided if the MFG's would put quality tires on at the factory. Anyone actually try to find a trail express or similar tire for replacement? I found one on line back when I was looking for info and the price was less than $50.00! I have heard some numbers on what the tires cost the mfg's while at the hitch hiker factory...most frames cost less than 150.00 for 4 tires!! There are bicycle tires that are more expensive and likely better quality. Are there folks that have had no problem with the OEM tires? Sure, but there are way too many failures for FR to continue to ignore. When I plan on up grading units I will negotiate a better tire into the deal....I would suggest others do the same. Might as well pay up front for a safer tire rather than 200-1000 miles down the road.
2019 SOB Bunkhouse (Former Coachman FR Owner)
2015 Ram Bighorn 2500 6.4L
https://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 12-19-2013, 08:49 PM   #35
davel1971's Avatar
I was going to buy tire covers, but figured most tires wont last long enough to dry rot anyhow
David & Lynn
Old 12-20-2013, 01:45 AM   #36
OL Creeker's Avatar
I wonder how many think their N filled tires had the "air" pumped out? My tires have that green valve stem cover too. Ok, I probably just opened a can of worms. So?
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 12-20-2013, 06:22 AM   #37
davel1971's Avatar
that depends on how it was done. There are machines that will pull it down, partially charge it, pull down again, then fully charge.
David & Lynn
Old 12-20-2013, 07:33 AM   #38
LKicklight's Avatar
Sort Of
Condensation builds inside the tire and wheel and when the sun hits the outside walls, the heat tries to suck that condensation from inside the tire, bingo, tire rot and cracking from the inside. Our last set of tires on the Sunnybrook were at the six year age limit, sure enough we got on the road with them, great tread still on the tires. There date code was 03' it is not early 2010, think we drove like 96 miles when the first tire blew. Stopped in Kitty Hawk, NC and purchased a brand new set of Continental ten plys: Used the coach one more year, now sits on our deeded lot in N GA. and not moved in three years: Go figure!
Originally Posted by caper View Post
The unknown part is when the unit is being towed from the manufacturer to the dealer. Did the tires hit a lot of pot holes, did the driver strike a curb, and did the driver keep the speeds below 65mph? Also when the unit left the manufacture facility were the tires at the proper pressure? The main cause of tire failure is not keeping your tires covered when not being towed. The sun can and will dry out the tires and cause weather cracks.
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 12-20-2013, 07:37 AM   #39
LKicklight's Avatar
Balancing
We were told that balancing the coach wheels were not necessary as they are aluminum 18" pieces. Never really went along with that idea, thinking before we leave for Alaska next summer to get all balanced off the coach and install the nitrogen!
Old 12-20-2013, 08:53 AM   #40
Any info on the ST Provider tires than came on my new 5'ver? If they are a problem I would definitely like to take care of it.
06 D-Max CC 4X4
2014 Wildcat 344QB-OK
EastTexan is offline   Reply With Quote
tire, tires
