Old 10-22-2015, 05:45 PM   #1
Send a message via AIM to NoviBill
Quick and easy tank blowout connector
I made this in about 5 minutes and $2. It allows me to set my compressor to 30psi and connect it to the fresh water supply to blow out all the lines.
I used a compressor quick connect, a dollar store quick hose connect and a 1/2 inch drill bit.
Quick and Easy RV Blowout quick connect for compressor by cdrdwd, on Flickr
Bill & Renee from Novi, Michigan
2006 Lexington 255DS
http://anunbalancedbalance.blogspot.com/
NoviBill is offline   Reply With Quote
Old 10-22-2015, 06:38 PM   #2
Jim Schings's Avatar
Well nothing new, but cheaper than most... :
Amazon.com: Camco 36143 Blow Out Plug with Brass Quick Connect: Automotive
Jim and Katy
w/ Shelby and Sealy (Bernese Mountain Dog and a Nice Mut)
FR3
HAM CALLSIGN - AI4SR
EE, IBMer, Race Car Builder, now Retired.
Jim Schings is offline   Reply With Quote
Old 10-22-2015, 06:55 PM   #3
mud yapster's Avatar
Thanks for the idea, going to make one myself. I had something rigged up last year but can't find it now.
Here we use the 5er year round but when I know it's going to get real cold I blow out all the lines. Putting RV antifreeze in here is a waste of money so the air is our best option. Thanks again for the idea.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 10-22-2015, 06:56 PM   #4
Didn't even need an npt tap for the air chuck fitting.
Old 10-22-2015, 07:07 PM   #5
Blackhat6mike's Avatar
I bought two of these last year. One had a air chuck and the other a tire valve stem. I think I paid $9 for the two. They can be used with either kind of compressor. I doubt I will ever use either one as I live in SE GA and we don't winterize, but good to have just in case.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 10-22-2015, 07:43 PM   #6
mark0224's Avatar
Had brass quick connect got a brass threaded fitting that fit both the waterline and the quick connect for under $3 .
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 10-23-2015, 11:07 AM   #7
I use these two things:
Iwritecode is offline   Reply With Quote
Old 10-23-2015, 01:35 PM   #8
PhilB's Avatar
Originally Posted by Jim Schings View Post
New to the RV world, thanks for posting this.
We Travel Not To Escape Life But For Life To Not Escape Us
2015 Wildcat Maxx T28RKX
PhilB is offline   Reply With Quote
Old 10-23-2015, 03:29 PM   #9
05 gtown xl 375 ts
go easy with the psi you can blow water line joints I use only about 10 psi and wife opens and closes Fawcett's one at a time till only air then do outside fawcet
glenn56h is offline   Reply With Quote
Old 10-23-2015, 05:59 PM   #10
Originally Posted by glenn56h View Post
05 gtown xl 375 ts
I would be more concerned with blowing water line joints with campground city water than with air. I use a pressure regulator at 40 psi with city water with no problems so have no worries with air at 40 psi as well.
DRiveWell is offline   Reply With Quote
Old 10-24-2015, 09:20 AM   #11
Wolverine 1945's Avatar
I made my own,,, Male hose connector on one end,,, air chuck on the other,,, it is about 3 feet long,,, made with garden hose,,, and a gas valve in the middle,,, I like it because I can stop the flow of air any time I want !!! And it also gives the compressor a chance to build pressure back up !!! Of course I get the DW to help !!!
Wolverine 1945 is offline   Reply With Quote
Old 10-26-2015, 07:42 AM   #12
how do you make sure the pump is dry?
Rich H.
[/SIGPIC]
Solera 24R - 2014
Life is Good - All is Well
richhop25 is offline   Reply With Quote
Old 10-26-2015, 07:54 AM   #13
I run 2 gallons of antifreeze thru the hole system after I blow it out,,,
WTH,,, Cost less than $6 !!!
Old 10-27-2015, 08:43 PM   #14
mark0224's Avatar
The only way, I've found, to make sure the pump is protected is to fill it with antifreeze.
Old 10-28-2015, 07:07 AM   #15
I am sure the antifreeze left in the pump & the faucets is better than dry !!!
As for the seal in the stool also !!!
Old 11-03-2015, 09:43 AM   #16
muddyrode's Avatar
I tore apart an old air compressure and took the fittings and the the pressure regulator off and made one that will screw in to my hose connection that has the regulator and pressure Guage on it works great that way i dont have to screw with my compressure and have every thing right there
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 01-18-2016, 03:16 PM   #17
Very handy. I also made one similar to yours. I use it to blow out the pressure washer, too.
377FLIK
kasedian is offline   Reply With Quote
Old 01-18-2016, 03:29 PM   #18
Oaklevel's Avatar
Ooooooops Thanks, forgot about the pressure washer need to do something with it ........Its cold !!!!!!!!!!
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 01-18-2016, 09:28 PM   #19
Send a message via Skype™ to Falcon35
The first time I blow out the lines I didn't think about the water pump. I was lucky that it only broke the glass bowl on the filter in line before the pump. I replaced the filter and everything was okay. Have anyone found a way to make sure the pump is cleared?
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrakeô Surge Brake System integrated with ReadyBruteô Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
Old 01-19-2016, 12:29 AM   #20
Usually Confused Member
emm-dee's Avatar
I use air to blow out all the lines, pull the rod on the water heater, etc. Then, if the temperature is going to get below 40į I leave a small ceramic heater/blower that puts warm air into the open cabinet doors to keep the pump from freezing.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
tank
