Old 06-14-2017, 08:46 AM   #1
Wolverine 1945's Avatar
Re-Painting Skylights ???
Last year I brushed 5 coats of Rustoleum Ultra White paint on our Skylights over 5 days,,, it did a Great job of cutting down the Heat !!! This winter much of the paint blew off !!! I am wanting to repaint and am thinking I must prime first,,, my question is what have you guys that have painted yours use as a pre-cleaner before priming ??? The last thing I want to do is damage the plastic
I was thinking rubbing alcohol ???
Wolverine 1945 is offline   Reply With Quote
Old 06-14-2017, 09:00 AM   #2
On my sky light in the bathroom,I removed the inner panel of the sky light. I then installed a solar film on that.Toned down the brightness and greatly reduced the heat build up.Been on there a year and still going strong.Did the same on our other 5er and it was still good when we traded after two years. Saying this,I would try to remove what old paint is on there and completely prime and repaint.Depending on the paint you used, I don't think rubbing alcohol will remove it. I would ask a paint store for something.
2011 Ram Mega Cab 3500 Larimie dually
2016 Chaparral 370FL
DaveandSue is offline   Reply With Quote
Old 06-14-2017, 09:04 AM   #3
Head Rambler
The best thing to use to paint the skylights is a dedicated plastic paint. Rustoleum makes one as well as Krylon. I personally like the Rustoleum better, but either will work. Clean it well with paint thinner or mineral spirits.
The trick to getting it to last is to apply it in thin coats allowing it to dry between coats.
Also, if you're looking for the maximum light blocking, spray it first with 2 or 3 coats of white and then spray over it with 2 or 3 coats of black, and finish it off with a couple of coats of white if you want the top coat to be white. Or you could just leave it black.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 06-14-2017, 09:21 AM   #4
Thanks Guys !!!
I was thinking that Paint Thinner might damage the Plastic ???
Not sure the wind would allow me to spray paint ???
I did last year before I replaced the little bath vent,,, sprayed it with Krylon Fusion !!!
It held up very well !!!
Old 06-14-2017, 09:27 AM   #5
jeff64's Avatar
Removed inner panel of skylight (shower location). Wiped both surfaces with rubbing alcohol and painted underside of dome and top side of inner panel with Rustoleum white frosted paint. Looks pretty good seems to have cut the heat. Rustoleum said it was appropriate for the plastic . No outside exposure on the paint on either of the surfaces. Finished job appears translucent white.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 06-14-2017, 09:44 AM   #6
Semperfi24's Avatar
Maybe there is a reason for this question to be no, but why not paint the skylight on the inside, not the outside, with a plastic specific spray paint. Then it will never be out in the elements.
_________________________
2018 Rockwood Mini Lite 2504S
2018 Ford F150 Lariat Special Edition 3.5 Ecoboost
Semperfi24 is offline   Reply With Quote
Old 06-14-2017, 09:53 AM   #7
Painting the inside might be a very good Idea !!!
But for me @ this point I need to re-paint the outside !!!
Old 06-14-2017, 10:23 AM   #8
I cleaned mine with rubbing alcohol and painted it with plasti-dip in a spray can. Been on there for 2 years with no issues. But mine is stored under a shed roof when not in use. I'm sure that helps keep the UV rays from deteriorating it.
2016 Flagstaff 23LB
howie70 is offline   Reply With Quote
Old 06-15-2017, 06:24 AM   #9
Mine was fine until winter,,, then it blew off in big pieces,,, it was thick and pliable !!!
Should have done a better job of prep !!! I think I will try Rubbing Alcohol & Primer !!!
I would spray them with Krylon Fusion,,, but the wind is always blowing !!!
Thanks all !!!
Old 06-15-2017, 09:39 AM   #10
Kenny kustom's Avatar
When painting plastic, use an adhesion promoter. It will stick much better, and not flake off.
2017 Dynamax Isata 4
Old 06-16-2017, 06:52 AM   #11
Is an Adhesion Promoter different than a Primer ???
Old 06-17-2017, 08:41 AM   #12
It is a form of primer, helps it stick better.
Old 06-17-2017, 08:47 AM   #13
Thanks Kenny !!!
I Googled it,,, sounds like a good product to use !!!
Rust Oleum has one that is clear !!!
Old 06-18-2017, 01:40 PM   #14
SilhouettePenny's Avatar
Etching primer is the answer your looking for.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 06-18-2017, 01:47 PM   #15
Scoundrel
HangDiver's Avatar
I got a sun shade for an auto windshield, cut it to the dimensions of the sky light opening and attached small strips of velcro to the window frame and made-to-order sun shade. Keeps the sun/heat out; take it off when you want.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is online now   Reply With Quote
Old 06-19-2017, 05:27 AM   #16
I tried that a few years back,,, every time it got hot in the MH they would fall down !!! Even tried gluing the velcro to the skylight frame !!! With the outside painted,,, the covers now stay up !!!
I plan to look for some spray primer next time I get out,,, & hopefully get some help from one of my Grandsons !!!
Old 06-27-2017, 05:03 PM   #17
The velcro does not work on mine using the silver insulation. When it get hot it would fall down. I had an old foam mattress pad. I cut to fit. Placed to strings across opening. Placed the foam pad above the strings. Holding good so far.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
Old 06-28-2017, 05:38 AM   #18
Had the same problem with the velcro,,, even tried gluing the velcro up !!!
I got some adhesive primer the other day,,, ZINNZER BOND !!!
hoping for dry weather tomorrow !!!
Old 06-28-2017, 06:10 AM   #19
Gumpster808's Avatar
We have been looking for options for this as well. The white blinds that cover the skylight may as well not be there.
Anyone seen other types of blinds? That may be an option as well.
Lynn & Dennis
Nights Camped 2017 - 35 / 2018 - 15
2014 3051S - First RV for us
2018 Hyundai Elantra Sport Toad
2015 Harley CVO (retirement bike )
2015 Challenger ( Wife's Toy)
Gumpster808 is offline   Reply With Quote
Old 06-28-2017, 06:18 AM   #20
We took or cloth shade down,,, straighten it up the best we could,,, sprayed the H out of it with spray starch,,, like some lady said here back some time ago,,, and then put a pic of Foil Insulation above it,,,
Looks some what better than the sagging Pic 0 Crap it was !!!
That shade needs some support in the center !!!
Of course a painted Sky light also helps !!!
light, skylight
