Old 06-08-2012, 08:02 PM   #1
? re: tile on walls
Can someone tell me who has put tile on their camper walls, like in the kitchen, has the grout cracked? Or will it in time?
thanks
Vicki
sprint180 is offline   Reply With Quote
Old 06-08-2012, 08:48 PM   #2
Never done it but I think it could crack of come off in time.
imabmwnut is offline   Reply With Quote
Old 06-08-2012, 08:51 PM   #3
caper's Avatar
I would not put tiles on the wall. The plywood is too thin and the grout will crack with the movement of the camper. If you want the tile look you could use tile board.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 06-08-2012, 09:40 PM   #4
Twisty's Avatar
Use silicone grout or caulk.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 06-09-2012, 04:57 AM   #5
cpaulsen's Avatar
I have done that before....in fact....just finished installing granite tile and backspash on my Wildcat for the bathroom and kitchen.
cpaulsen is offline   Reply With Quote
Old 06-09-2012, 06:46 AM   #6
RonLynnJr's Avatar
You could use the Peel and stick metal tiles that don't require grout
Ron, Tami, Annette, and Ron III
United States Coast Guard Active Duty
2011 Salem 28BHSS / 2004 Dodge 2500 Cummins
2012 reserved/camped (17/4)
RonLynnJr is offline   Reply With Quote
Old 06-10-2012, 10:23 AM   #7
There was a longer thread on this a few months ago with lots of info.
I would never attempt this in an RV until someone suggested using caulking material instead of grout. Ordinary grout will surely crack and fail due to substrate flexing. Caulk is available in a sanded version in various colors that looks more like regular grout.
That could be a lot of joints to caulk. Keep in mind that once caulk has dried, it does not stick to itself so you need finish it all at once. Also, it skins over in 5 minutes or so and you need to keep moving quickly and clean the excess off as you go. Don't wait until it has dried to clean it off. You should practice on a separate test area first. You need to be adept at laying down the caulk and cleaning it up before putting it down permanently on a finished wall.
I would at the least install a plywood backing sheet of say 1/4" thick and fasten it securely to the wall studs. You can then use Schluter edging to hide the ply and tile edge.
I suppose you could consider installing tiles without grout joints. It's "just" an RV and not a house where it gets grime + water on it 24/7/365.... I'd still install ply backing so tiles don't crack or fall off. Only problem might be that some tiles are not dimensionally consistent from piece to piece.
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
Old 06-10-2012, 11:09 AM   #8
Twisty's Avatar
Solid surface counter top material could be cut to size with the top edge and ends rounded over. The corners would be mitered. Very clean look and maintenance free. Install with liquid nails or something similar.
2012 Surveyor SV264
NW Oregon
