Old 08-27-2012, 05:26 PM   #91
Got my two fans mounted and operational, 1) 80mm and 1) 90mm. With both fans going, you can feel the heat coming out of the roof vent. Temp inside frig is holding @ 33° with the control set at 2 and outside temp @89°. Very pleased with the setup. I may bolt a deflector to the outer edge of the fans so the air is directed straight up so it does not deflect off the accumulator and out the lower vent. I want all the air going up the chimney and out the roof vent.
Name:	Dual fans 1.jpg
ID:	18786   Click image for larger version
Name:	Dual fans2.jpg
ID:	18787   Click image for larger version
Name:	One 80mm and one 90mm.jpg
Old 08-28-2012, 06:03 PM   #92
M109Rrider's Avatar
At 89-91 degrees could you not get those temps before the fans?
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 08-28-2012, 06:08 PM   #93
TURBS's Avatar
1) I could not maintain a temperature .
2) fridge temp ran mostly in the 36 to 38 range
my fridge cooled to 32 degrees in about 9 hours . it could have been less but I only checked when I got home from work .
Old 08-28-2012, 06:24 PM   #94
I could get the temps, but the control had to be set @4 instead of 2 and if the outside temp went to the high 90's and low 100, I had to set the control to 5 to hold the frig at around 34°-35°. It just makes the whole system work so much more efficient for our situation. For no more expense and effort to install, I think it it well worth it.
The gas burner just does not cycle as much. As far as saving propane, I imagine it is negligible, but every little bit helps.
Old 08-28-2012, 06:44 PM   #95
M109Rrider's Avatar
Cool, glad you got the results you needed.
Jason and Billie
fan
