Old 08-17-2012, 08:59 PM   #21
TURBS's Avatar
I'm think mine will end up yonder yet to !
Old 08-18-2012, 07:30 AM   #22
We have the 18EC as well and live in Florida and haven't had any issues with the Fridge keeping food cool. You probably already power up the fridge a day before leaving for you destination, but if not this helped a lot. We did notice that the propane cools better than when on electric...not sure why?
madelle is offline   Reply With Quote
Old 08-18-2012, 10:11 AM   #23
One possibility: Perhaps propane provides more BTUs than
the electric heating element. More heat input = more ammonia
boiled = more cooling in fridge.
Propane definitely provides more heat for the water heater than
electric; wouldn't surprise me if the same is true for the fridge.
cheers,
johnd
2001 Cherokee CKT27X - 2005 Chev 3500
Sara, John & Crafty Canines - Coco and Cole
Medical research shows that men have a "biological clock" too. The older we get, the greater the NEED to drive a TRUCK!
dnaraG_1M is offline   Reply With Quote
Old 08-18-2012, 10:55 AM   #24
Originally Posted by f1100turbo View Post
Yes they are at the bottom of vent.
I'm goin to play with placement as I go to see if I can get even better air flow .
Right now when fans are on I can suck a napkin up to the vent.
Ron
I may try to mount my new 120mm fan(if it ever gets here) just below the vent cover on the roof. That way I will have one below blowing up and one on top blowing out and helping the lower fan. Depending on what I find, I might even make a shroud.
Old 08-19-2012, 04:51 PM   #25
Mark S's Avatar
Installed my radio shack 4 inch computer fan at the intake vent pointing up to the coils. Seems to move a pretty good amount of air to the top of the compartment. I could not find a 12 volt source that was switched with the refrigerator so I hooked to a constant hot and added a toggle switch. My thinking is I will turn the fan on when I turn the refrigerator on and off when I return home. I left the original temperature controlled fan just below the upper side vent as it was. I guess as it gets hotter that fan will turn on to assist. I can see how a top vent would let the heat escape much more efficiently.
Attaching the new fan was fun as they really don't give you much room to work in.
Mark and Joanne
2014 Fun Finder XT 276
2015 Ford F150 Lariat 3.5 Ecoboost 4X4 SCrew Max Tow
2011 Harley Road Glide Ultra
Mark S is offline   Reply With Quote
Old 08-19-2012, 05:33 PM   #26
Dennis and Julie's Avatar
What is wamer than you want as long as it isn't above 42 degrees or below 34 degrees all should be good. Ours runs right about 40 and everything is plenty cold, even the milk. This keeps the freezer right about 8 degrees.
Dennis and Julie
2018 Wildcat 28SGX
2013 Chevy Silverado 2500HD
2012 Chevy Silverado 2500HD
Dennis and Julie is offline   Reply With Quote
Old 08-19-2012, 06:37 PM   #27
Herk7769's Avatar
Best place to install would be to take roof cover off and instal in vent stack .
Yup. That is where my fan booster is going.
The solar powered fans are on my "To Buy" list.
The only mod I want to do is to figure out a way to only power the fans in sunlight and when the fridge is powered.
HAM CALLSIGN - KC3FFW
Old 08-19-2012, 10:30 PM   #28
herk.
If you want to run the solar powered fans only when the fridge is on,then run the 12v fridge "on" to power a relay to switch the solar power to the fan.
09grizzly1
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
09grizzly1 is offline   Reply With Quote
Old 08-19-2012, 11:20 PM   #29
Shouldn't be to hard. Just run 12v fridge on power to a photo cell that pulls in a coil and powers your fan.
2012 Lacrosse 318BHS
07 Ford F-350 Super Duty
Hilgy is offline   Reply With Quote
Old 08-20-2012, 06:27 AM   #30
Herk7769's Avatar
Originally Posted by 09grizzly1 View Post
herk.
09grizzly1
Maybe I am over thinking this.
It all depends on how noisy the solar fans are.
I don't want to hear a noisy fan at night.
Anyone have one installed?
fan
