Old 08-20-2012, 06:35 AM   #31
TURBS's Avatar
I've now removed the 120's and installed 2 80 mm fans in the ducting vent.
I found that there was a filler panel that I could remove and cut to fit the fans on it .
Now the fans are horizontal blowing air up the vent stack.
I'll take pics tonight
Old 08-20-2012, 09:53 AM   #32
M109Rrider's Avatar
#####Please learn from my mistake####
I had a hard time cooling my fridge in July at Myrtle Beach so I bought a computer fan and installed it in the bottom blowing up. It made it worse, my fridge warmed up even more and we had to throw everything away. Those bottom coils have to get hot for the fridge to work. All your trying to do with the fan is assist the chiminey effect to remove heat. The coils at the top are the ones that need heat removed. I since moved my fan to the top and it works great. I simply zip tied it to the top vent cover.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 08-20-2012, 02:15 PM   #33
herk.
The solar panel fans should not run at night as there is no sunlight to create power for the fans.The relay would only switch the power from the solar panel to the fans when the fridge is turned on.I'm assuming you are talking about the the solar panels that are on the fridge vent.
09grizzly1
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
09grizzly1 is offline   Reply With Quote
Old 08-20-2012, 04:03 PM   #34
TURBS's Avatar
Who has a pic of the factory mounting of a fan ?
Old 08-20-2012, 08:37 PM   #35
TURBS's Avatar
Anyone?
Old 08-20-2012, 09:17 PM   #36
bob213's Avatar
Herk, if you go with solar fans you will want to put a toggle switch inline so you can shut them off when your trailer sits in the sun while NOT being used.
bob213 is offline   Reply With Quote
Old 08-21-2012, 06:36 AM   #37
Herk7769's Avatar
I knew I was "over thinking" this.
I was trying to make it automatic using a feed from the "run" DC line to power a relay to feed an inverted output photocell to power on the solar fans.
First off, the solar fans won't run at night anyway! (VERY embarrassed.)
Second, the relay will work (there are several cheap ones) but will increase battery drain by the amperage draw of the relay. (only a few milliamps buy I am trying to avoid battery drain at all.
A manual switch solves everything.
NASA invents the "Space Pen" at a cost of a million dollars.
Russia uses pencils.
HAM CALLSIGN - KC3FFW
Old 08-21-2012, 06:38 AM   #38
TURBS's Avatar
What is the amp draw on your fans ?
Old 08-21-2012, 06:45 AM   #39
Herk7769's Avatar
Zero. Solar powered by integrated solar cells.
Old 08-21-2012, 07:06 AM   #40
TURBS's Avatar
Lol was supplying you a duh moment !
He he he he.
Kinda like when you u joint goes out of your truck and the driveshaft is laying on the ground but u still put it in park !
I was messing with ya.!
fan
