Old 08-21-2012, 09:25 AM   #41
VinceU's Avatar
Originally Posted by f1100turbo View Post
Who has a pic of the factory mounting of a fan ?
Don't have a pic to give you, only a verbal desp based on dwg I have. In a Dometic 1350 Two fans are mounted side by side on the back of the refrig assembly using a sheetmetal U- channel attahed to the box. They are simply sheet metal screwed into the channel. They are located just below the finds of the condenser assembly for max flow across the unit. I don't think where yours were mounted would really make a difference in performance. The boiler is insulated and covered in sheetmetal to keep the heat in. If you had 50 cu ft./ miniute flow caused by a top fan or a botom fan, its still the same 50 cu. ft./min with the same temp rises on the air flow. The bottom location justs impedes access to connections and electronics. The only access in my installation is to remove the large 200 lb. box for access. Thiis is why some folks have mounted jut below the outside acccess cover. Mine whine, but no big deal, barely hear them anyway. Dometic web site, Model RM1350 back view assembly drawing.
Old 08-21-2012, 09:35 AM   #42
VinceU's Avatar
Originally Posted by herk7769 View Post
Zero. Solar powered by integrated solar cells.
Kinda cool, whats the CFM rating of these fan(S)? I know some of these folks are going quite high with flow capacity, maybe into subcooling. Thats why the factory uses thermostatic switches to keep the uptake in a range. If the solar fans worked well, could keep the factory fans only opering ocasionally, like on dark/or hot days.
Old 08-21-2012, 04:41 PM   #43
VinceU's Avatar
I knew I was "over thinking" this.
I was trying to make it automatic using a feed from the "run" DC line to power a relay to feed an inverted output photocell to power on the solar fans.
First off, the solar fans won't run at night anyway! (VERY embarrassed.)
Second, the relay will work (there are several cheap ones) but will increase battery drain by the amperage draw of the relay. (only a few milliamps buy I am trying to avoid battery drain at all.
A manual switch solves everything.
NASA invents the "Space Pen" at a cost of a million dollars.
Russia uses pencils.
Lou,
Forget my question CFM, its looks tiny and it is. Read reviews on numerous sellers and the thing is pretty badly rated. Fails in sun (plastic cracks), moves very little air, provided no help to inside temps, solar panel failed and fan failed etc. Save your 'C' note.
Old 08-21-2012, 04:46 PM   #44
TURBS's Avatar
Well I removed my 120mm fans and installed two 80 mm fans in first pic.
The blow up the vent stack and not On the lower coils.
The second pic shows were I go 12v switched power .
When you remove cover it's the lower right terminal.
Dometic model dm2852rbx
Old 08-21-2012, 06:43 PM   #45
Herk7769's Avatar
Vince,
Thanks for the input. JohnD set a MOSFET controller circuit via PM and with your input to save my money on the "commercial version" I am going to build a solar powered fan set to mount on my existing cap.
A smallish solar panel mounted on my existing rain cap that drives a pair (or 3) of 120mm 12VDC box fans directly under it using a MOSFET controller circuit for on/off control may very well do the trick.
Photos and parts list when I get around to building it this fall.
HAM CALLSIGN - KC3FFW
Old 08-21-2012, 06:47 PM   #46
Vince,
You still haven't mounted the gas struts on the doors yet!
Old 08-22-2012, 05:12 PM   #47
Attachment 18462
Attachment 18463
Good job, good job!!
Let us know how it affects the fridge
performance......
cheers,
johnd
2001 Cherokee CKT27X - 2005 Chev 3500
Sara, John & Crafty Canines - Coco and Cole
Medical research shows that men have a "biological clock" too. The older we get, the greater the NEED to drive a TRUCK!
dnaraG_1M is offline   Reply With Quote
Old 08-22-2012, 05:13 PM   #48
TURBS's Avatar
performance......
cheers,
johnd
I'll know first of next week.
Old 08-22-2012, 06:07 PM   #49
Herk7769's Avatar
Blah, Blah, Blah...
Jeeze, I am ready to ship them back!
Old 08-22-2012, 06:11 PM   #50
Here is where I mounted mine and it really makes a big difference in how the refrigerator cools. It worked great even when we had temps in the upper 90's and low 100's and the sun on the back of the camper. Will mount a 120mm fan down inside the area under the roof vent cover when it gets here later this week. The upper fan will be just added ventilation. Have dual fans inside the refrigerator hanging on the fins and the temp holds around 33-35 constant even in the hottest weather we've had.
ID:	18512   Click image for larger version
fan
