Old 08-22-2012, 06:41 PM   #51
Originally Posted by herk7769 View Post
Blah, Blah, Blah...
Jeeze, I am ready to ship them back!
Don't want them back, still have 3 gathering more dust laying on a shelf.
Old 08-22-2012, 06:54 PM   #52
xf021209's Avatar
Mounted a single computer power supply fan on top of the external cooling fins. Amazed at the difference. Cool down was 1/3rd to 1/2 the time. I use a manual switch to control it. Since most of time I'm in parks with power I don't worry about running the fan all the time. Just be careful not to cool the ammonia can at the bottom. It's supposed to be hot. The little battery operated internal fans help to keep everything in the refrigerator at equal temperature.
Todd - 2006 Forest River 27BH (previous FEMA trailer, rebuild in progress.) https://www.facebook.com/media/set/?...1&l=1506dbb708
EPDM Rubber Roof Installation - http://www.youtube.com/watch?v=xbraK...hannel&list=UL Pulled by a 2002 Chevy Avalanche, 496cid Rat motor, 12k Lb. tow package, leveling hitch, dual sway controls & electric brakes.
xf021209 is offline   Reply With Quote
Old 08-22-2012, 07:10 PM   #53
TURBS's Avatar
Originally Posted by dunnnc
Here is where I mounted mine and it really makes a big difference in how the refrigerator cools. It worked great even when we had temps in the upper 90's and low 100's and the sun on the back of the camper. Will mount a 120mm fan down inside the area under the roof vent cover when it gets here later this week. The upper fan will be just added ventilation. Have dual fans inside the refrigerator hanging on the fins and the temp holds around 33°-35° constant even in the hottest weather we've had.
Looks good.
Do u have a filler panel at the top of that access panel?
That filler panel is what I cut the circles in to mount mine
Old 08-22-2012, 07:17 PM   #54
Herk7769's Avatar
Are you talking about the flat plate to the right?
Name:	Camper Fridge 001.jpg
HAM CALLSIGN - KC3FFW
Old 08-22-2012, 07:19 PM   #55
Originally Posted by xf021209 View Post
...Just be careful not to cool the ammonia can at the bottom. It's supposed to be hot...
The can at the bottom is the accumulator tank and just stores the liquid ammonia. If the fan is doing it's job, the can should be cool. The ammonia is pulled from the tank and boiled in the stack.
Old 08-22-2012, 07:34 PM   #56
TURBS's Avatar
No the filler panel above the shield.
First pic shows the filler panel with fans cut in .
Second shows a view further back.
Old 08-22-2012, 07:51 PM   #57
Herk7769's Avatar
Originally Posted by f1100turbo View Post
Attachment 18518
Attachment 18519
I need to look at mine tomorrow.
Old 08-22-2012, 07:54 PM   #58
Looks good.
Don't have a filler panel as far as I can see up the cavity. Will know more when I take the roof vent cover off. Will definitely take pictures.
Old 08-22-2012, 07:56 PM   #59
TURBS's Avatar
I never even seen it before .
Then when I was deciding on whether to mount fans in upper end of vent stack via taking of the top vent cover I seen this filler panel.
When I removed it (two screws) I could see all the way up to the top vent cover.
So what better place to mount fans.
If it doesn't work out I'll make a new filler panel.
Old 08-22-2012, 07:58 PM   #60
TURBS's Avatar
Mine is obviously obtained from bottom.
I'll need to get better lighting to take a few better pics.
fan
