Old 08-15-2012, 01:48 PM   #1
Mark S's Avatar
Refridgerators: Are two fans better than one?
Camping in really warm weather this summer, my refrigerator was a bit warmer than I would like. I was ready to order a coil fan for my refrigerator when I looked to see how difficult it would be to install and I found I already have a fan. Would I benefit by adding a 2nd fan?
Mark and Joanne
2014 Fun Finder XT 276
2015 Ford F150 Lariat 3.5 Ecoboost 4X4 SCrew Max Tow
2011 Harley Road Glide Ultra
Mark S is offline   Reply With Quote
Old 08-15-2012, 03:16 PM   #2
TURBS's Avatar
I'm installing two 120 mm fans on mine.
Old 08-15-2012, 06:29 PM   #3
TURBS's Avatar
Install done.
Old 08-16-2012, 07:20 AM   #4
Mark S's Avatar
Are those fans at the bottom / intake of the vent? I couldn't tell from the photo. It seems to me that pushing the air past the coils would work better than pulling at the top. Mine came with a single fan at the top vent, which I read is the "right way". I am thinking now of adding two computer fans at the bottom and repositioning the top one.
Mark and Joanne
Old 08-16-2012, 09:21 AM   #5
Originally Posted by f1100turbo View Post
Attachment 18114
Install done.
Not sure from the photo, but it looks like the right side fan
is blowing at the combustion chamber (and heat stack).
Not a good idea, is it to cool the stack?
Would it not be better to have them blow on the
condenser coils or suck air at the top of the vent?
Expiring minds want to know...........
cheers,
johnd
2001 Cherokee CKT27X - 2005 Chev 3500
Sara, John & Crafty Canines - Coco and Cole
Medical research shows that men have a "biological clock" too. The older we get, the greater the NEED to drive a TRUCK!
dnaraG_1M is offline   Reply With Quote
Old 08-17-2012, 02:22 PM   #6
Mark S's Avatar
Why does the fan need to be temperature controlled? Unless it was freezing out, wouldn't the refrigerator benefit from constant ventilation of the coil area? I ask this because I am standing in a puddle of sweat (August in south Florida) waiting for the installed top fan to turn on. What would be the downside to a constant on fan venting the coils?
Mark and Joanne
Old 08-17-2012, 02:42 PM   #7
TURBS's Avatar
Mine runs if the fridge is running.
Albeit I installed them myself.
I think imo that they should run as long as fridge is on.
Ron
Old 08-17-2012, 03:13 PM   #8
TURBS's Avatar
cheers,
johnd
Mine are sucking from the vent side as to help aid in cooler air running through system. Placement of the fans have no particular rhyme or reason other tHan being close to the vent to draw cool fresh air.
Ron
Old 08-17-2012, 03:17 PM   #9
TURBS's Avatar
Yes they are at the bottom of vent.
I'm goin to play with placement as I go to see if I can get even better air flow .
Right now when fans are on I can suck a napkin up to the vent.
Ron
Old 08-17-2012, 03:22 PM   #10
Ron
I think they would be much better utilized if they were horizontal and blowing from the bottom of the coils up toward the roof. That's where the cooling is needed.
Old 08-17-2012, 03:55 PM   #11
TURBS's Avatar
Lol to do that Id need about 15 1" x 1" fans as it is there's no room to get fans to push air directly out vertical vent stack
Best place to install would be to take roof cover off and instal in vent stack .
Old 08-17-2012, 04:00 PM   #12
Where there is a will there is a way. When I get my other one, I'll take pictures of how to place them. lol
Old 08-17-2012, 04:06 PM   #13
TURBS's Avatar
Mind you I'm using 120 mm fans
Old 08-17-2012, 05:35 PM   #14
Mark S's Avatar
My exhaust is through a side vent panel just above the refrigerator , not though the roof. So the one small fan just doesn't do it. I just spent a while with my volt meter and I cannot find a 12 volt line that is switched by the refrigerator being on. All easily accessed lines are constantly hot. Where did you find a switched line?
Mark and Joanne
Old 08-17-2012, 05:53 PM   #15
TURBS's Avatar
What fridge do you have?
I had to take cover off of the circuit board on lower left of fridge .
On that board lower left there's a red wire that says 12v switched
That is what I used
I can take a picture Sunday
Old 08-17-2012, 06:17 PM   #16
onetonford's Avatar
http://i32.servimg.com/u/f32/15/82/45/87/fans_i10.jpg
This is how I have mine set up and they a thermostatly controlled they run slow at first and as things warm up they speed up also they are alot quieter and move more air then old one hooked up to original wiring that controlled old fan works great it improved how the Refrigerator works by 25%...
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 08-17-2012, 06:35 PM   #17
TURBS's Avatar
Can you take pic of a bigger view of fridge?
Old 08-17-2012, 07:08 PM   #18
onetonford's Avatar
Not at the Moment but I have some other views they are all taken from the top compartment Door because the Refrigerator is in the slide...
http://i32.servimg.com/u/f32/15/82/45/87/fans_i11.jpg
http://i32.servimg.com/u/f32/15/82/45/87/fans_i12.jpg
http://i32.servimg.com/u/f32/15/82/45/87/fans_i13.jpg
http://i32.servimg.com/u/f32/15/82/45/87/fans_i14.jpg
http://i32.servimg.com/u/f32/15/82/45/87/fans_i15.jpg
http://i32.servimg.com/u/f32/15/82/45/87/fans_i17.jpg
http://i32.servimg.com/u/f32/15/82/45/87/fans_i18.jpg
2011 25 RL Wildcat
Old 08-17-2012, 08:12 PM   #19
DougP47's Avatar
Just a question “If you’re trying to get the heat moving. Would it be better to have the fans blowing out, or the lower one blowing in and the top blowing out? I installed a fan on the inside coil and it only runs when the door is closed. I seem to have more adjustment left if I want it colder. Your thoughts thanks for letting me barge.
DougP47 is offline   Reply With Quote
Old 08-17-2012, 08:36 PM   #20
Ron
What I was getting at is that I think that there is a rhyme/reason
to avoid cooling the combustion chamber. An ammonia fridge
is a thermodynamic engine - a heat pump - driven by heat
input which boils the ammonia to start the condensation/
evaporation cycle which moves heat from the source (fridge
evap coils) to the sink (condensation coils).
If you reduce the heat input, you will boil less ammonia and
thus reduce efficiency. I think you want to cool the condenser
coils and allow the combustion chamber to get as hot as it was
designed to be in order to have maximum efficiency.
And yes, I don't know the order of the effect, but every little
bit helps when the ambient temperature is in the 100's.
Just ordered my 4 fan bank from allelectronics. We'll see if that
helps in the 100+ temp here. Plan to put them at the top of
the vent. Perhaps that design will suck big time!
cheers,
johnd
fan
