Forest River Forums
Sunline User Photos
Old 01-15-2012, 09:45 AM   #1
refrigerator freezing everything
After countless adjustments to the plastic thinga-ma-gig holding the little wire do-hickie on the aluminum fins in the reefer it still freezes everything from milk and tea to beer and salad dressing and lunch meat.
It's a Dometic mod# RM 2852 gas/electric in a 2002 FR Windsong MH.
On electric service it will freeze everything in 24-36 hrs. on gas it takes a few days but will freeze stuff.
Just can't find the right setting/adjustment.
Is this an exceptionally great reefer or something the matter and is it hurting the unit??
Any suggestions????
cdrifter/working nuke-refinery traveler
'02 windsong
'02 toyota 4-runner (toad)
Florida cracker working in Louisiana
cdrifter is offline   Reply With Quote
Old 01-15-2012, 09:50 AM   #2
Try turning your refrigerator off every other day
pops is offline   Reply With Quote
Old 01-15-2012, 10:12 AM   #3
RubenZ's Avatar
are we talking hard freeze or just little ice in the liquids?
__________________________________
Ruben Zamora
2007 Silverado 2500HD 4x4 Dmax/Allison, 4" Exhaust-no cat-no muffler
2012 Palomino Puma 23FB
RubenZ is offline   Reply With Quote
Old 01-15-2012, 10:29 AM   #4
we are talking SOLID!!!!!!
eggs frozen in the shell,picante sauce froze solid,balonga like hard frisbees.
That kind of frozen
cdrifter
Old 01-15-2012, 10:37 AM   #5
tonyz's Avatar
Before diving into the unit it's self, I would check to make sure there is a good door seal. If the door is open even the slightest bit, it will run continious and feeze up.
tonyz is offline   Reply With Quote
Old 01-15-2012, 10:45 AM   #6
seal seems to be good . no moisture or obvious gaps around seal.freezer is full and frig is about 1/3 full of stuff. maybe freezer so cold it is overriding temp control in lower compartment???
Just guessing now!!!!
cdrifter
Old 01-15-2012, 11:02 AM   #7
Moderator
The little plastic slide is just a holder. The wire, with the bulb on the end, is really the sensor. You can pull the plastic thing off the ins, and make sure the bulb is mounted correctly, and in your case, near the bottom of the plastic holder. Also needs to be as close as possible to touching the fin. Reinstall with it at the bottom of the fins. This should be the warmest setting. If it still freezes after you do the above, sounds like maybe a control board issue. Might also want to get a cheap automotive Air Conditioner thermometer, and put in it, just to get a real reading on temperature.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
windrider is offline   Reply With Quote
Old 01-16-2012, 09:53 AM   #8
RubenZ's Avatar
take a pic of your sensor and how its mounted
Ruben Zamora
Old 01-16-2012, 02:03 PM   #9
Moderator
Pics of Thermistor in Refer
As for a pic, do you know how hard it is to get a 35mm camera in a 5 cubic foot refer? I didn't, so I had to find out. I'll show what I can.
1. Pic of plastic clip on the fin. On mine, left side, and adjusted near the bottom.
2. is the thermistor itself. Just pulled it out of the plastic clip so you could see it.
3. Tried to get a pic of the thermistor bulb in the plastic clip.
4. One last pic of the bulb in the clip. ready for reassembly.
Just make sure that when you move the plastic slider, that the wire moves with it. The plastic piece is just a holder for the thermistor bulb. It is the bulb that has to move. Make sure the wire isn't binding somewhere, or pinched, and not moving at all. Hope you can see the bulb is small compared to the plastic holder. the bulb goes down for a warmer fridge, and up for a colder one.
Windrider,
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
Old 01-16-2012, 02:07 PM   #10
Moderator
mtnguy's Avatar
Thanks, windrider. I too have been having trouble with my fridge getting too cold, so I will check things out....might have to wait until spring, though.
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
mtnguy is offline   Reply With Quote
» Online Users: 578
121 members and 457 guests
2011sv264, 4bnabird, 4Jeeperz, Adony, adp1326, ayotte, B47, bayouboys, Bigmatt, bikeman911, bikendan, bka4tcu, bob213, Bob_Loblaw, boubou, Buffalohunter, bush, buzzmonster, caper, carsonizik3, Cccross3, cgreen1509, chevy02, cllecr, crawford, cyclepuck, dasimser, daw592, ddemme, DeeMax, dezolen, donh, donn, Drmstx62, Dutch & Di, fast murray, Fire Instructor, forensicdeac, FreedomTracker, gb73071, gimp425, GlacierGus, greran, h20ski, Happy Campers 79, hark582, Hilgy, hjmiberry, itat, Itsthetwoofus, J McClure, J R, JamesR, jasni, jimandjoyhamel, jjhwisconsin, JJL, johnthecamper, Jsroberts5, jsutherl, jtstromsburg, Kellahut1, Kirby, KRS, kwjeepxj, Mad4sax, manvel, Margaret, Marsh707, meatguy, michel, MikeT, Mnflyboy, MrAllen, mtfd515, mwilson949, ncgrl1, newtsx3, NO3putt, nowait, ohiobill, partime, patov6, Pawpod, peaeye, Phil1, PHS79, punkaccountant, rgfenner, RJHuser, rkswyo, rmason8092, RockyMtnHigh, Rsgtivr6, sandys, Sbbs2228, sbond, Sg6923, showtime0022, SinkorSwim, sjones7246, Smithee, snackage, Stedman1, steeleshark2, Steve7575, sundawg, Swinks, Tekknogeek, tentcamper1, Terier, thom01, Tincup13, tking1866, troyt, trudinator, VinceU, vp22er, Waterfowlwarrior, WestCoastRV'er, Westernflyer
Most users ever online was 1,025, Today at 01:04 PM.
Close [X]
