Old 04-22-2011, 04:55 PM   #1
remove slideout
I need to remove the slideout on a 2006 26 ft. Forrest River rv. How do you remove it ? Pictures of track with slideout removed would help. Thanks.
ddeadfred is offline   Reply With Quote
Old 04-22-2011, 05:04 PM   #2
My first question is...why?
Jack
2018 Flagstaff 832IKBS Travel Trailer.
2015 Silverado High Country.
jackhartjr is offline   Reply With Quote
Old 04-22-2011, 05:19 PM   #3
slideout removal
Slideout is sitting slightly lower on right hand side . It won't extend all the way out without picking up on that side.
Old 04-22-2011, 05:23 PM   #4
Removing it would be a drastic measure...I am sure there must be an adjustment somewhere that would 'fix' your problem without that 'drastic' move!
There are some pretty bright folks here that will help you.
Some photos would helps us help you.
Jack
Old 04-22-2011, 05:30 PM   #5
jimh's Avatar
will this help? it may give u some ideas...
jimh is offline   Reply With Quote
Old 04-22-2011, 05:38 PM   #6
slideout removal
Didn"t help but thanks for the response. Mine has an electric motor and
a screw shaft to extend and retract it. Have a nice day!
Old 04-22-2011, 05:56 PM   #7
jimh's Avatar
i was hoping that there would be enough similarities that it would help. if i can find it, i may have one on a motorhome that uses cables to pull it in and out.
was hoping that what it slides on and the adjustments would be similar.
Old 04-22-2011, 06:07 PM   #8
jimh's Avatar
no don't have anything else. probably on an older computer.
the motorhome one was a utube video. it was interesting but probably isn't close.
