Old 03-15-2018, 07:06 PM   #1
TLAK's Avatar
Removing contact cement from clear coat
I've gotten some contact cement on the back of my FR3. Roofing cement on top of the clear coat. Any ideas for removing it without wrecking the surface?
2015 FR3 30DS
Towing 2016 Chevy Sonic LT
TLAK is offline   Reply With Quote
Old 03-16-2018, 11:02 AM   #2
I would apply heat and then scrape with a plastic scraper or razor scraper removing as much as possible. Follow up with a citrus based remover and see if that will soften enough so you can peel the rest away it away. Mineral spirits and acetone will work but you will certainly impact the finish so I would use those sparingly.
ray98 is offline   Reply With Quote
Old 03-16-2018, 11:28 AM   #3
Just as confused as you
Scrapper's Avatar
If it is truly contact cement there is no need to go through all the trouble ray98 suggests. The long time remedy had been to let it set up and use a rubber school erasure on it.
Learned this back in grade school 50 yrs ago.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 05-07-2018, 05:21 PM   #4
TLAK's Avatar
The eraser woks, but itís slow if you have a big. Spot. 3m adhesive remover worked but its$13 a can. Isopropyl alcohol works almost as well at about 99 cents a quart.
My rig is looking much better now! Thanks for all the clues
2015 FR3 30DS
