Old 01-05-2016, 07:31 PM   #11
Terier's Avatar
Originally Posted by B and B View Post
X2 Over Under!! 37 years of doing this as a profession! However the Walmart cheapo RV hose is a tough go no water you do..
Good videos. My storage doors are very narrow so I am limited to a small size container which means tight coiling. My previous water hose finally became trained but someone stole it and now I'm dealing with a new hose that is a bit stubborn. I never heard of Over Under but it does make sense and try it next time I roll up my water hose.
In watching the videos I quickly learned that I am killing my cables with how I rolled them up. I like the tip of draining the water first then roll up. I have been draining the water as I roll it up but sometimes I end up wet.
Old 01-05-2016, 07:32 PM   #12
I always disconnect and lay hoses out straight as possible then start to roll (you will drain hose at the same time). Hoses and cables have a "natural lay" to them. You will need to twist the hose to keep that "natural lay" in check. You can coil hose on the ground or in hand and each coil should lay flat if it doesn't lay flat or if it kinks you didn't twist enough. Warm hoses are much easier to deal with.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is online now   Reply With Quote
Old 01-05-2016, 07:37 PM   #13
If you have some one hold the other end of hose a pull hard a couple times. It will help relax the hose and make it easier to deal with. Just don't pull on the connectors, cheap ones will pull out.
Hensley Arrow
Old 01-05-2016, 07:38 PM   #14
Fulltime family RVer
30' of flat hoses for the win.
Old 01-05-2016, 07:45 PM   #15
Terier's Avatar
I wish having someone help was an option as I am a solo camper. Would it help to reconnect to the faucet and give it a good tug get out the kinked/twisted part?
Attachment 97324
I'm jealous...
I almost brought that type but the sales person talked me out of it.
Old 01-05-2016, 07:57 PM   #16
I would not do that. You could put it on soft ground and put a truck wheel on it JUST DON'T CRUSH CONNECTOR! Or do it on a cold day.
Hensley Arrow
Old 01-05-2016, 08:03 PM   #17
Left Coast
Change hose...most that kink once will always do it...the lay-flat hoses, made lately, might work. I have a 50' 3/4" fire hose that came out of old mill...it's a lay flat type
Old 01-05-2016, 08:14 PM   #18
I'm jealous...
I like them. But, I took Herk's suggestion and bought 10' "utility" hoses. This kind of hose can't have any sharp bends or it blocks the flow of water. The 10' sections make it very manageable.
Old 01-05-2016, 08:46 PM   #19
I like to use shorter hoses; not over 25'. have a 25 & 2 10's. Never have need any more & shorter hoses are much easier to handle.
Papa GLS is offline   Reply With Quote
Old 01-06-2016, 08:43 AM   #20
Head Rambler
I agree with the 25' hoses. I have several potable water hoses that I store in a clear 28 quart Sterilite tote that's 23" L x 16¼" W x 6" H I can get 75' of hose, the filters and all the fittings (90º el, spring flex end, regulator, etc.) in it and it fits nicely in the passthru drawer.
Also, when I roll up the hoses I always connect the ends together, and I usually leave the filter connected to one of them.
Gotta go campin!
