Old 01-05-2016, 07:11 PM   #1
Rolling up hoses
I have extremely hard time rolling up water hoses without them kinking. Has anyone got suggestions for this. Also how to store these same hoses. Tia
Sandy and Steve
Chooie, Baby, Grizzly, Sophie the 4 fur babies
2018 Rockwood 8301WS fiver
2003 Ford F-250 super duty diesel
Vinemont, AL
Triple SS is offline   Reply With Quote
Old 01-05-2016, 07:14 PM   #2
Left Coast
Need to twist (roll) as you roll up. Practice using extension cord
Old 01-05-2016, 07:20 PM   #3
Oaklevel's Avatar
It helped me when I started buying a higher quality hose. My cheap one always kinked........
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 01-05-2016, 07:42 PM   #4
You are going to have to explain this to me.
Sandy and Steve
Vinemont, AL
Old 01-05-2016, 07:45 PM   #5
DDC
DDC's Avatar
I coil it into a bushel basket, works well.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 01-05-2016, 07:56 PM   #6
BamaBob's Avatar
X2 What Donald suggests. I bought a "Homer Bucket" from Home Depot and coil my water hose in the bucket then remove it and bag it (water hose fits great in bags designed to hold side mounted BBQ grills!) Then I coil my 50AMP cord into the Homer Bucket, and put our Progressive EMS unit in the center. Cable & hoses done!
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 01-05-2016, 08:03 PM   #7
Ford Idaho's Avatar
" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350">
Old 01-05-2016, 08:03 PM   #8
You can join the Navy and they'll teach you (or else!).
BIRDS AREN’T REAL
Old 01-05-2016, 08:04 PM   #9
Canadiancrew's Avatar
Check these videos and they will explain it. First one talks about the twist and the second calls it the over and under method.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 01-05-2016, 08:11 PM   #10
B and B's Avatar
X2 Over Under!! 37 years of doing this as a profession! However the Walmart cheapo RV hose is a tough go no water you do..
B and B
Old 01-05-2016, 08:31 PM   #11
Terier's Avatar
Good videos. My storage doors are very narrow so I am limited to a small size container which means tight coiling. My previous water hose finally became trained but someone stole it and now I'm dealing with a new hose that is a bit stubborn. I never heard of Over Under but it does make sense and try it next time I roll up my water hose.
In watching the videos I quickly learned that I am killing my cables with how I rolled them up. I like the tip of draining the water first then roll up. I have been draining the water as I roll it up but sometimes I end up wet.
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
Old 01-05-2016, 08:32 PM   #12
I always disconnect and lay hoses out straight as possible then start to roll (you will drain hose at the same time). Hoses and cables have a "natural lay" to them. You will need to twist the hose to keep that "natural lay" in check. You can coil hose on the ground or in hand and each coil should lay flat if it doesn't lay flat or if it kinks you didn't twist enough. Warm hoses are much easier to deal with.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
uhduh camping is offline   Reply With Quote
Old 01-05-2016, 08:37 PM   #13
If you have some one hold the other end of hose a pull hard a couple times. It will help relax the hose and make it easier to deal with. Just don't pull on the connectors, cheap ones will pull out.
Hensley Arrow
Old 01-05-2016, 08:38 PM   #14
Always Learning
30' of flat hoses for the win.
Old 01-05-2016, 08:45 PM   #15
Terier's Avatar
I wish having someone help was an option as I am a solo camper. Would it help to reconnect to the faucet and give it a good tug get out the kinked/twisted part?
Attachment 97324
I'm jealous...
I almost brought that type but the sales person talked me out of it.
Old 01-05-2016, 08:57 PM   #16
I would not do that. You could put it on soft ground and put a truck wheel on it JUST DON'T CRUSH CONNECTOR! Or do it on a cold day.
Hensley Arrow
Old 01-05-2016, 09:03 PM   #17
Left Coast
Change hose...most that kink once will always do it...the lay-flat hoses, made lately, might work. I have a 50' 3/4" fire hose that came out of old mill...it's a lay flat type
Old 01-05-2016, 09:14 PM   #18
Always Learning
I'm jealous...
I like them. But, I took Herk's suggestion and bought 10' "utility" hoses. This kind of hose can't have any sharp bends or it blocks the flow of water. The 10' sections make it very manageable.
Old 01-05-2016, 09:46 PM   #19
I like to use shorter hoses; not over 25'. have a 25 & 2 10's. Never have need any more & shorter hoses are much easier to handle.
Papa GLS is offline   Reply With Quote
Old 01-06-2016, 09:43 AM   #20
I agree with the 25' hoses. I have several potable water hoses that I store in a clear 28 quart Sterilite tote that's 23" L x 16¼" W x 6" H I can get 75' of hose, the filters and all the fittings (90º el, spring flex end, regulator, etc.) in it and it fits nicely in the passthru drawer.
Also, when I roll up the hoses I always connect the ends together, and I usually leave the filter connected to one of them.
Gotta go campin!
