Old 10-08-2014, 10:48 PM   #11
Rent a ozone generator.. Place in fridge close door best you can in a few hrs.. You should be all set...if you rent a room size unit.. You can do the entire RV in a day or two..You just can't be in the Rv when the ozone generator is running..
Good luck
2010 Georgetown 300FWSSouth Florida
speedjester is offline   Reply With Quote
Old 10-09-2014, 08:27 AM   #12
Liltrouble728's Avatar
Thanks for all the ideas guess I better get working bad thing is we are living in the rv because we just moved from Washington to Missouri
Liltrouble728 is offline   Reply With Quote
Old 10-09-2014, 10:25 AM   #13
Coffee grounds. Take a plate or whatever will fit in frig, and spread out coffee grounds. Run frig. overnight. Used to work for a trucking company and that is what we did after hauling onions. Coffee would absorb the smell.
MKClark is offline   Reply With Quote
