Old 10-08-2014, 07:58 PM   #1
Liltrouble728's Avatar
Rotten Meat!!!
So my husband left some meat in the freezer and now we have rotten meat all over any ideas how to get the stink out or how to remove the fridge?
Liltrouble728 is offline   Reply With Quote
Old 10-08-2014, 08:15 PM   #2
This may help
http://m.wikihow.com/Get-Rid-of-Bad-...in-Your-Fridge
jwedell is offline   Reply With Quote
Old 10-08-2014, 08:16 PM   #3
I have had first hand experience with this, Chicken..... During the summer we left the freezer on in 100 degree heat for two weeks, could smell it from outside. The freezer blew a fuse and quit working. The good news is you can clean it up and get the smell out. Use lots of cleaner, open all the windows, use more cleaner....a anti-bacteria kitchen cleaner works best. Then when you can not clean anymore line the bottom of the freezer with newspaper get a big bowl of coffee grounds and put it in the freezer and close the door for a couple of days, you will need to do this a couple of times then use the boxes of arm and hammer baking powder for as long as you can changing them often. the smell will decrease fairly fast, and you may smell a few wiff's here and there but it will go away. Trust me I thought that I would have to replace the fridge as it was really, really bad. I was able to save it.
Mike, Lisa and Jake
2002 Ford F250 CC 7.3
2013 Wildcat Sterling 32RL
MMattox is offline   Reply With Quote
Old 10-08-2014, 08:16 PM   #4
jonrjen's Avatar
Take some paper plates or foil pie tins and load them up with baking soda then place them in the frig and freezer, it will absorb the smell with time.
Or you can also lay news paper on the bottom of the freezer and place charcoal on it, the charcoal will also absorb the odor.
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 10-08-2014, 08:21 PM   #5
Baking soda and vinegar rub.
rana is offline   Reply With Quote
Old 10-08-2014, 08:22 PM   #6
asquared's Avatar
Scrub it really good with a Clorox cleaner. You may also want to try doing a baking soda wash down. Leave the freezer open and pick up some Zeolite. This stuff works miracles on bad odors. It is rechargeable too. Just sit it in the sun for six hours and it's ready for use again.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 10-08-2014, 08:31 PM   #7
Use comet or Ajax and a scrub brush with hot water. Clean all spots the chicken or the liquids came in contact. Repeat this procedure several times and allow to dry thoroughly between times. Place an auto deoderizer inside and close fridge. A few weeks in the hot sun and all traces of the odor should be gone.
comfun1 is offline   Reply With Quote
Old 10-08-2014, 09:22 PM   #8
CAT-RN's Avatar
Rotten Meat!!!
I hate to be the bearer of bad news--- but on our coach we did about everyone of the above options. Even boiled a vinegar solution & soaked newspapers in it and put in closed freezer. Everything we did got maybe 90% of the smell out.
Nothing got all that smell out. Finally had dealer replace Frig. $1500 if I remember right???
Russell
CAT-RN is online now   Reply With Quote
Old 10-08-2014, 09:28 PM   #9
Don't know first hand but have been told that you can also put some charcoal in a couple of cups and it is suppose to absorb the odor. Just a suggestion I have heard about.
2003 Dodge Ram 2500 5.9 Diesel
2014 Rockwood 2608WS
Big Paul is offline   Reply With Quote
Old 10-08-2014, 10:26 PM   #10
Iwannacamp's Avatar
I think it's only like aquarium charcoal. It's called activated charcoal. A quart would be a good start. I used to use X-14 mildew and stain remover to clean used(stinky) refrigerators I got to fix and resale.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
