Old 04-03-2012, 09:15 PM   #31
Herk7769's Avatar
Well that is pretty self explanatory!
HAM CALLSIGN - KC3FFW
Old 04-03-2012, 09:17 PM   #32
TURBS's Avatar
I was hoping that I wasn't going to over sell it !
Old 05-23-2012, 11:33 PM   #33
1l243's Avatar
I liked the idea of lighting up the outside of the trailer when the need arises. I wanted to be able to control it from the inside so I added a
switch.
1l243 is offline   Reply With Quote
Old 05-24-2012, 12:13 AM   #34
rexerito's Avatar
http://www.rvglow.com/
rexerito is offline   Reply With Quote
Old 05-24-2012, 02:14 AM   #35
Namchief's Avatar
For $3.00 I can make my own
Time spent 2012 in TT 32 days so far and 21 Planned days this Fall with mini trips in between
2009 Chevy Silverado 1500
2012 XLR Hyper Lite 27HFS
1999 Yamaha Grizzly
1996 HD Dyna Wide Glide
Namchief is offline   Reply With Quote
Old 05-26-2012, 08:35 AM   #36
Dovetail's Avatar
by golly - it works!!
Rick and Linda, Lindale, TX
2011 Flagstaff 8528 CKSS
2006 F350 SW
Camping nights 2013: 130
Camping nights 2014: 17
Dovetail is offline   Reply With Quote
Old 05-27-2012, 12:27 AM   #37
bush's Avatar
i tried the fuse in the 2 top pins and all i got was the tail lights??
2011 puma unleashed 298fqu toyhauler.
hauling a 2012 polaris RZRS
pulled by a 2006 chevy 3500 drw 4x4 duramax lbz
bush is offline   Reply With Quote
Old 05-27-2012, 07:51 AM   #38
Herk7769's Avatar
The fuse (or flasher unit) goes between the ground and the running lights.
Name:	Trailer Wiring.jpg
ID:	14482   Click image for larger version
Name:	Connector Pin Out.gif
Old 05-27-2012, 08:23 AM   #39
MtnGuy's Avatar
Either your marker lights are not working, or you are jumping between the battery charge and the brake/signal light prongs.
On Lou's pictures, you need to jump between the prongs at 11 and 1 o'clock.
Old 05-27-2012, 08:27 AM   #40
MtnGuy's Avatar
Lou, I think that should be between the battery charge and running lights.
led pad
