Old 05-27-2012, 08:38 AM   #41
Herk7769's Avatar
Originally Posted by bush View Post
i tried the fuse in the 2 top pins and all i got was the tail lights??
Assuming you picked the correct pins in the socket:
You could also have a "ground" problem on your trailer's lighting since you have tail lights (not stop lights) and no running lights.
Normally, your exterior "traveling" light bulbs get their ground and the power to light them through the tow vehicle (from pins on the tow vehicle's socket and the ground pin which is connected to the camper's frame on the camper side and the truck's frame on the other).
You are not using that path since you are using the camper's 12VDC system to light your running lights by shunting through the fuse.
The camper's 12VDC has to make it through the running lights and back to the camper's battery through the frame of the camper. If that connection is corroded (for the running lights), that MIGHT cause only part of the lights to work.
HAM CALLSIGN - KC3FFW
Old 05-27-2012, 08:39 AM   #42
Herk7769's Avatar
Originally Posted by mtnguy View Post
Lou, I think that should be between the battery charge and running lights.
yep, not enough coffee, yet.
Old 05-27-2012, 10:34 AM   #43
B47
Originally Posted by wood family 77437 View Post
I have a friend who said that in the past he has seen TT's parked at sites that have the running lights on, and being used as extra lighting around the TT independent from truck. I know that there are issuses in doing this, but i cant figure out how it is done any thoughts. Thanks
OK - I'll be the fun spoiler here - why would you want to do this at the CG?
Running lights are for that one purpose - "running"
This sort of sounds like your CG neighbor who plays his music too loud.
Old 05-27-2012, 10:44 AM   #44
pbrackney's Avatar
I agree. I do not mind awning lights. They have a purpose. But if I am camping, the last thing I want to see is the TT next to me lit up like a Christmas tree. Campfires are nice when the sun is down and so are lights. Please be considerate of the campers around you. Although it may look cool to you it can be annoying to those around you. This is all said in a nice way, just some other thoughts on the subject. Happy camping to all.
Philip, DW, 3 DD, 1 DS, and Ginger our Dog
2017 Wildwood 30QBSS
2003 Ford Expedition 5.4 Liter with 3.73 Axle
Equalizer 4-Point Sway 12000# & Tekonsha P3
pbrackney is offline   Reply With Quote
Old 05-29-2012, 08:27 PM   #45
i also put a switch inside my lower front compartment bin, i just opened the junction box for the trailer wiring and put a switch in between the charger feed and the green running light feed, works great and now my neoghbors at the trailer park are now doing the same!
spud7378 is offline   Reply With Quote
Old 05-29-2012, 08:58 PM   #46
MIKE44460's Avatar
I added a 7 pin female to the TT battery, fused the positive side. And now since all of my running lights are LED's it does stand out. In addition my side running lights also work with the turn signals. I found that this works very well to get someone out of the blind spot.
Mike & Lu Anne
& our Jack Russell 'Genny'
2011 Flagstaff 831FKBSS
2011 Chevy CC Duramax Z/71
OH plate GM DMAX
Hensley Arrow
MIKE44460 is offline   Reply With Quote
Old 05-29-2012, 09:09 PM   #47
1l243's Avatar
Light polution? Really, what are the lights 4 watts each? There is a time and place. If I have the guy right next to me with his awning rubbing on the side of my trailer I probably would not turn them on but If I am forest with wide spaces between each site and I want to have a little light around the trailer I will turn them on... I will keep my campfire down low though.....
1l243 is offline   Reply With Quote
Old 05-29-2012, 09:33 PM   #48
TURBS's Avatar
Originally Posted by herk7769
The fuse (or flasher unit) goes between the ground and the running lights.
Between 3 and 4
Old 05-30-2012, 03:37 PM   #49
pbrackney's Avatar
Love it!
Old 05-30-2012, 03:45 PM   #50
Dodge Guy's Avatar
Running lights are dimmer than awning lights! And it makes it alot easier to roll up an awning with an approaching storm when you dont have lights hanging off of it!
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
led pad
