Old 12-04-2013, 10:34 PM   #11
Capt. Mike's Avatar
Make sure you get your anti-freeze completely flushed out of the system next spring BEFORE you "un-by-pass" (is that a word?) and fill the water heater. If you get antifreeze in the water heater and get it hot, it takes forever to get rid of that odor/taste. We had that problem on our boat once. If I recall, it took about a gallon of bleach run through the hot water heater to get the odor/foul taste out.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
“It's not how old you are, it's how you are old.”Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 12-05-2013, 12:40 AM   #12
Engineer of Crazy Train
ChooChooMan74's Avatar
Originally Posted by RamblerGuy View Post
Taste in the water? Why would you drink it?
I don't think he means drinking the antifreeze, just the water in the system tastes bad due to the antifreeze. Lots of flushing to get the taste out.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 12-05-2013, 02:45 AM   #13
Just a member
kandl's Avatar
Some use a pump to push antifreeze through the fresh water system, but some of us just put it into the fresh water tank and let the coach's pump do the work. A problem doing this with our Sunseeker is that the tank fill is high and trying to hold a funnel and the antifreeze over your head is asking for trouble. A 2 liter soft drink bottle is a perfect fit for the tank fill. I use a funnel from the kitchen to fill the bottle from the antifreeze jugs. I don't want anything from a funnel from my shop to be washed into the tank.
Are there no provisions to blow out the lines in the Sunseeker? That would remedy the grief associated with getting antifreeze into the FW tank and save some bucks on antifreeze.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 12-05-2013, 05:54 AM   #14
davel1971's Avatar
I made a brass fitting for several dollars (better than plastic junk at RV dealers). Turn down regulator on air compressor to about 30psi, hook to city water hookup. Open each faucet and flush toilet to remove all water. Remove air, drain low point drains to get last little bit out. System is now empty and can be filled with antifreeze without diluting it. All can be done in under half hour for under $20
David & Lynn
Old 12-05-2013, 06:46 AM   #15
jriddering's Avatar
2x. Best way to do it.
Jim and Carol
2012 Crusader 290RLT
2010 Ford F-250 King Cab Diesel
Harley Davidson Edition
jriddering is offline   Reply With Quote
Old 12-05-2013, 06:56 AM   #16
Dave Lyon's Avatar
Originally Posted by Ford Idaho View Post
I would never put A/F in my fresh water tank.
X2.......however, to each their own.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 12-05-2013, 06:57 AM   #17
bobcrowder's Avatar
Why does everyone keep talking about dumping a gallon of pink stuff into the traps? don't you get plenty in there when you turn on the faccuet and let it run for a few seconds while it chugs out the air? I also put AF in FW tank and pull it in. Never noticed a bad taste after flushing. But we don't really drink the water at the CG anyway. We always take bottled water for drinking.
2012 F150 4x4 5.0
2011 Cherokee Grey Wolf 26bh
God Bless America
bobcrowder is offline   Reply With Quote
Old 12-05-2013, 07:08 AM   #18
My sunseeker (3050s) didn't have enough room to put a bypass valve before the water pump. My old RV did which allowed you to suck the AF right from the bottle. I would prefer doing that, but putting it in the fresh water tank was the only way. I'll see in the spring how much of a pain it it to flush it out.
johnlantz is offline   Reply With Quote
Old 12-05-2013, 07:11 AM   #19
Ford Idaho's Avatar
I agree 100%, but I bought an inline filter to use before the F/W tank to keep unwanted gunk out.
I'll be hanged before I put something in there like A/F on purpose.
I would just blow the system with air and forget the A/F.
Old 12-05-2013, 08:28 AM   #20
No worries. It will come out of out the tank just like it comes out of the lines.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
antifreeze, fresh water, tank, water, water tank
