Old 05-26-2017, 06:02 AM   #1
Safety chains vs Class V hitch
For those that have fought trying to attach 5/16" slip hooks on your chains to the holes in a class V hitch, a little tip. If hook has safety latch, simply use a Dremel and grind off about 3/16" from end of latch, use Dremel to recut notch in center of latch and they fit like a glove on your class V.Click image for larger version
ID:	139084Click image for larger version
TheWolfPaq82 is offline   Reply With Quote
Old 05-26-2017, 08:51 AM   #2
thanks---nice tip........
nibroc is offline   Reply With Quote
Old 05-26-2017, 08:52 AM   #3
Prime Member
I installed larger hooks.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
Forever in my memory and in my heart. Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 05-26-2017, 08:58 AM   #4
The problem I saw, larger hooks usually require larger chain. 1/2" hook was going to require larger links for clevis pin to fit thru. This fix is zero dollars and took 10 minutes to do both sides.
Old 05-27-2017, 11:28 AM   #5
I put a large chair link on the truck.
NorSnrub is offline   Reply With Quote
Old 05-27-2017, 11:34 AM   #6
Good idea, but I use shackles. Also gives me a place to tie my emergency brake cable.
2012 Windjammer 3001W
2016 Sunset Trail Super Lite 250RB-For Sale
2015.5 Chevrolet Silverado 2500HD LTZ crew cab Z71 4x4
KingFisher is offline   Reply With Quote
Old 05-27-2017, 11:39 AM   #7
Georgia Rally Coordinator
aceinspp's Avatar
Good tip but I just removed them altogether never had them on any of my other trailers. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 54
Old 05-27-2017, 12:20 PM   #8
Prime Member
3/8" hooks
Old 05-27-2017, 12:46 PM   #9
Just as confused as you
Scrapper's Avatar
Safety chains are required by law in all states.
Also, how many people new to towing know the chains are to be crossed under the tongue of the trailer. Left side of trailer to right side of TV, right side of trailer to left side of TV.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 05-27-2017, 01:09 PM   #10
Prime Member
Both my chains are attached at the same point under the trailer tongue so crossing them does nothing.
Old 05-27-2017, 01:47 PM   #11
Scrapper's Avatar
I know what your saying but if you look they will be connected in a left-right configuration. Connecting in a crossed pattern creates a cradle under the tongue. This helps prevent the tongue from digging into the ground/road if it becomes disconnected.
Richard & Jill
Old 05-27-2017, 02:03 PM   #12
Casey & Carolyn
Casey r's Avatar
2X on crossing the chains under the trailer tongue.
Casey r is offline   Reply With Quote
Old 05-27-2017, 02:25 PM   #13
Prime Member
I understand and agree with you but with both chains connected at the same point, no cradle is created.
Old 05-27-2017, 04:15 PM   #14
Scrapper's Avatar
I don't understand how that could be. Even if the mfg welded the center link to the tongue you will still have a left-right configuration unless one is behind the other, then one chain will be slightly longer than the other.
Richard & Jill
Old 05-27-2017, 04:58 PM   #15
Prime Member
Both my chains are attached to a common central point you can see in the photo.
Old 05-27-2017, 05:53 PM   #16
Too old to be too smart
SpringerPop's Avatar
Can you provide an image for this? I can't figure out what it is.
Thanks,
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 05-27-2017, 06:26 PM   #17
Attachment 139221
Looks like there is a common point of failure there, and it offers no redundancy at all if that loop breaks when the chains become the only things keeping your trailer behind your tow vehicle.
My current trailer is also arranged this same way, and I will be changing it to look like our old one, photo below.
Each chain is bolted to the outside of the frame with a fine-thread bolt, large washer, the chain, a spacer to give the chain's link some room to swivel, then through the frame, a large malleable iron washer, and finally two nuts jammed together and Loctited. All hardware except the iron washer is Grade-8. The assembly is just loose-enough to allow the chain link to swivel if some effort is exerted on it.
I don't know if it's any better for my efforts, but at least I tried to make it so, and it certainly allows for crossed chains.
I did it this way after I learned that Texas and Washington don't allow safety chains to be welded to the trailer. I used to tow through those states, thus the arrangement.
Pop
Old 05-27-2017, 06:43 PM   #18
Prime Member
That piece of metal the chains are attached to is more sturdy than the chains so the chains would fail first. Besides, the emergency brake switch cable is shorter than the safety chains meaning the trailer brakes would get fully applied before the chains even got tight.
Old 05-27-2017, 07:15 PM   #19
aceinspp's Avatar
You miss read I use the chains but got rid of the little clip and yes I've always crossed my chains for over 40 years. Later RJD
Days camped 2017 62
Days camped 2018 67
Days camped 2019 54
Old 05-27-2017, 07:41 PM   #20
Your arrangement won't pass muster (at least) in Washington State (and there may be more), as their law states, in part:
"The means of attachment of safety chains must: (a) Be located equally distant from and on opposite sides of the longitudinal centerline of the towing vehicle and of the trailer."
Yours is ON the longitudinal centerline.
It seems strange that RV manufacturers seem to build it so that it's legal in the state of delivery, irrespective of the other 49.
Anyways, you're a long ways from Washington.
Pop
hitch, safety
