Old 06-30-2012, 08:40 PM   #1
Question Satellite problem
Just purchsed a 2007 Lexington. Cannot get Direct tv to work. Checked box in house and worked fine. I think problem is not sure which cable to use. One is connected to booster and two are loose. The antenna is king dome. A wiring diagram would be nice. Also where do I check for 12 volt power to dome?
dunk05 is offline   Reply With Quote
Old 06-30-2012, 08:58 PM   #2
If you have a powered anttena on the camper, make sure you are not going thru it. It will not let the sat signal come through.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
rkswyo is offline   Reply With Quote
Old 06-30-2012, 09:09 PM   #3
Wink satellite problem
Thanks will check it out tomorrow
Old 06-30-2012, 09:33 PM   #4
Get one of these:
http://www.amazon.com/gp/product/B00...ls_o03_s00_i00
I had RG6 cables all over the place inside and I wasn't which went where. I hooked this up outside and took me about 5 minutes to find the feed from outside.
RickV is offline   Reply With Quote
