Old 06-03-2012, 09:46 AM   #21
caper's Avatar
On our unit we have a outlet where the gray and black converge to one pipe similar to yours. We also have a second gray tank that is located under our slide. When dumping we have to move the hose from the forward tanks to the rear tank. That is the reason we use the "Y" fitting.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 06-03-2012, 10:55 AM   #22
Dovetail's Avatar
I have the same kind of set up -- how do you connect the y fitting?
a short hose from each outlet to the y and then to the sewer??
I would love to do that setup -- picture possible??
Rick and Linda, Lindale, TX
2011 Flagstaff 8528 CKSS
2006 F350 SW
Camping nights 2013: 130
Camping nights 2014: 17
Dovetail is offline   Reply With Quote
Old 06-03-2012, 12:25 PM   #23
caper's Avatar
We connect the "Y" at the CG sewer inlet. Run a long hose from the front tanks and a short hose from the rear. We have installed a shut off on the front hose in order to leave the gate open on the tank. Will try and get pictures later today.
Terry and Janet
2007 Ford F150
Old 06-03-2012, 03:34 PM   #24
billy bob's Avatar
Sounds like you have a good setup for boondocking or dry camping with two gray water tanks, wish I had that problem. My gray water always fills up first with two I could drycamp 3 to 4 moew days before dumping.
billy bob is offline   Reply With Quote
Old 06-03-2012, 07:16 PM   #25
caper's Avatar
The front gray tank if for the bathroom sink and shower and the rear is for the galley sink.
Terry and Janet
2007 Ford F150
Old 06-03-2012, 07:29 PM   #26
Dovetail's Avatar
Caper, thx for the info on how u set it up. I'd hafto pick another hose up might be worth it
2006 F350 SW
