Originally Posted by caper
On our unit we have a outlet where the gray and black converge to one pipe similar to yours. We also have a second gray tank that is located under our slide. When dumping we have to move the hose from the forward tanks to the rear tank. That is the reason we use the "Y" fitting.
I have the same kind of set up -- how do you connect the y fitting?
a short hose from each outlet to the y and then to the sewer??
I would love to do that setup -- picture possible??
