Old 05-03-2016, 10:17 AM   #11
Originally Posted by Wheels Down View Post
Good idea. I have also seen this done with a rain gutter channel inside the post cover that slides out as well.
I have a gutter in mine that also serves as a sewer hose support occasionally. No need to remove the fence post.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 05-13-2016, 01:33 PM   #12
Akrap's Avatar
Hey that helps with what I am trying to do with mine. I got a brand new hose and of course the connection end does not fit inside the bumper. and the hose is about 12 inches too long. I don't want to cut the hose off. But might have too. I will still store in the bumper, but need to do something like that with a bigger end cap to fit the attachment end.
If you go with the flow, you miss too much.
Randy Pugh
Cadillac Escalade
Rockwood Roo 21SS
Moses Lake WA.
Akrap is offline   Reply With Quote
Old 05-13-2016, 02:10 PM   #13
Briorick's Avatar
Akrap, I pretty much did the same install as Rockfordroo except I installed mine on top of the bumper using 5" fence post and vinyl guttering. Installed with plumbers strapping and some self tap screws.
The little extra height makes for not so much work on the ole body to have to bend over as much. Quick and easy access, and it blends in pretty much with the back of the TT.
ID:	107769   Click image for larger version
ID:	107770   Click image for larger version
Rick & Brian
1 Happy Camper Pup ( Mya )
2017 Salem Cruise Lite 232RBXL
2004 GMC Sierra 2500HD LT 4x4 6.0 / 4:10
The best plans can be of those that happen in the spur of the moment!
Briorick is offline   Reply With Quote
Old 05-13-2016, 02:21 PM   #14
I brought a plastic box from Walmart that I store my sewer hose in and also the thing that holds up the hose. The sewer hose is two, 15ft and a 10ft hose combined. I also have another plastic box that I keep the water hose in and water pressure regulator. I have a 25ft one a me a 35ft hose that I brought cheap at Walmart.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 05-13-2016, 03:37 PM   #15
The only reason I used the fence post is because the 4" post inside will telescope out of the 5" post and it will act as a support for the hoses. I also made supports from 3/4" PVC that break down for storage.
PSEYFRIED is offline   Reply With Quote
storage
